08-14-2011, 09:42 PM | #1 |
can someone identify this wheel?
I picked up a set of these 15x8 4x4 GM 6x5.5 wheels.
Im going to have these blasted and powder coated soon so any information would be appreciated.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
08-14-2011, 09:57 PM | #2 |
Re: can someone identify this wheel?
They look like stock wagon wheels to me.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
08-14-2011, 10:01 PM | #3 |
X2 Looks like a stock wagon wheel 4wd, seems I only remember them on stepsides and blazers with rally center caps. Seen them in 5 lug too.
John 82 Chevy Silverado 350ci/TH350 |
08-14-2011, 10:07 PM | #4 |
They are factory becuase they have the threaded boss for the factory centercaps. I have seen 5 lug versions on sport truck models.
08-15-2011, 06:56 AM | #5 |
Thanks guys, anyone know what years these are from and if they were white or silver/rally color from the factory?
08-15-2011, 07:44 AM | #6 |
78K & 79C Jimmys
could be these 79
but mine look pointier in the triangle?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-15-2011, 09:25 AM | #7 |
Slots go on anything!
I don't thiink they are necessarily rare, but were another wheel choice from the mid 70's on. I am almost positive they were a shade of off white, and I don't remember them having trim rings.
edit- look at post 13 http://67-72chevytrucks.com/vboard/s...d.php?t=478950
1974 Jimmy- 5.3/4L80e/NP241 |
08-15-2011, 09:28 AM | #8 |
78K & 79C Jimmys
i seem to remember them with like a pin stripe in the rim
08-15-2011, 09:31 AM | #9 |
A lot of the aftermarket wheels had the pinstripes (usually red and blue), but the factory wheels did not.
08-15-2011, 09:37 AM | #10 |
did some more searching and they were a option code PA6 sport wheel, even the desert fox used them. Jon Bakers CHIP truck had them too
08-15-2011, 09:52 AM | #11 |
78K & 79C Jimmys
thanks just figured these were repainted......so stock with out...cool
08-15-2011, 01:14 PM | #12 |
by looking at brochures and articles it looks like they were offered from roughly 76/77-87
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
08-16-2011, 12:11 AM | #13 |
My '77 Chevy stepside 2wd was ordered with these PA6 white painted spoke rims. They are 8 inches wide.
I have a '79 Big Ten Chevy Silverado 2wd 1/2 ton with the same rims on it from the factory. I also have a 1980 GMC Sierra Classic Heavy Half 2wd 1/2 ton which is originally painted black with the gold center. The rims are the spoked rims which are painted gold to match the truck. I believe that it came from the factory like this as I have seen other trucks with the rims painted to match the truck. But I have been known to be wrong before...haha!!!! |
08-16-2011, 06:41 PM | #14 |
Watch out for your cornhole !
I think it's great that you're planning on having them blasted and powdercoated but if you want new ones, they are about 45 bucks each from Summit for a very similar wheel, lacking only the threaded center cap holes. A powdercoating shop is going to charge you way more than that to redo those wheels.
Just an option...
08-16-2011, 07:32 PM | #15 | |
PM me an estimate, I always wanted to throw you some business. heres what they would be going on
08-19-2011, 12:40 AM | #16 | |
08-19-2011, 01:13 AM | #17 | |
Thanks Alex. |
08-19-2011, 10:33 PM | #18 |
my 83 C10 had them from the factory and it was in fact off white, looked better than the glaring white of the aftermarket wagon wheels, and also had the more rounded edges to the holes. I never had the trim rings though, they were lost long before I got it. They were 8 inches wide, and I remember the woman I got it from used to buy tires from Western Auto. They went by the book which listed a 205 tire for the stock wheel which was narrower, and didn't take into account it had wider optional wheels. Needed at least a 235, I put 255s on it. So the 205 tires were way too narrow and looked terrible and wore out every year. She kept going back and they kept replacing them with the same size over and over. What a bunch of idiots. Thats part of the reason she hated the truck and I got it cheap
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
