Old 08-14-2011, 09:49 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Lets see Pics of Motor mounts and Trans crossmembers!
Post you pictures of you motor mounts (from engine to frame) and your transmission cross members!!!!
Going to make new ones and want ideas.
hotrod1 is offline   Reply With Quote
Old 08-14-2011, 09:59 PM   #2
Denee007
Denee007's Avatar
Re: Lets see Pics of Motor mounts and Trans crossmembers!
This is an excellent post! so, where are the pics?
dne'
Denee007 is offline   Reply With Quote
Old 08-14-2011, 10:38 PM   #3
hotrod1
56 - autocross
hotrod1's Avatar
Just started. Waiting for all these fab geniuses to post their pics.
Old 08-14-2011, 11:11 PM   #4
whid
sorry,bought mine from chassis engineering...motor and tranny mounts....highley reccomend them.......whid
whid is offline   Reply With Quote
Old 08-15-2011, 08:21 AM   #5
xpickup
xpickup's Avatar
hotrod1, Here is a picture of the one I built for the truck I am working on. I used 1 5/8 Dom tubing. It has 2 bolts at the pionts where it attaches to the frame. The motor mounts using the s10 V8 mounts , nothing special.
Shannon
xpickup is offline   Reply With Quote
Old 08-15-2011, 10:46 AM   #6
Speedbumpauto
Speedbumpauto's Avatar
Here is the one I did. I wanted to use the exsisting frame crossmember so I ground off the rivits and moved it forward about 8" and did the mods you see. The bottom is 2X3 tubing and it is held with bolts so it will drop out and allow me to remove the TH-400 and OD without taking everything apart. I try to plan for MURPHY as we seem to have a special relationship.
Speedbumpauto is offline   Reply With Quote
Old 08-15-2011, 12:59 PM   #7
mknittle
mknittle's Avatar
Yeah I know Murphy He lurks around here sometimes.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-15-2011, 01:21 PM   #8
solidaxel
solidaxel's Avatar
Will any of these help?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-23-2011, 09:21 PM   #9
parkwood
parkwood's Avatar
some shots of a '57 truck.
parkwood is offline   Reply With Quote
Old 08-23-2011, 09:33 PM   #10
hotrod1
56 - autocross
hotrod1's Avatar
Great shots parkwood.
Does anyone know why you do not see the transmission crossmember in back (closer to the tail of the trans) of the mount higher up with the mounting plate on the bottom of the tube so the trans corssmember is raised from the ground?
Old 08-23-2011, 09:46 PM   #11
parkwood
parkwood's Avatar
some taken from a '51 suburban
Old 08-23-2011, 10:00 PM   #12
parkwood
parkwood's Avatar
look at my next pictures from the suburban and see if that helps..
Old 08-23-2011, 10:09 PM   #13
parkwood
parkwood's Avatar
Not sure these will help because they're from a '52 chevy car.
Old 08-23-2011, 11:01 PM   #14
hotrod1
56 - autocross
hotrod1's Avatar
Thanks Parkwood. I appreciate all the pictures. Want to get a good compilation of pics not only for me but for others wanting to see the same thing.
