Old 08-14-2011, 10:23 PM   #1
wannagettachevy
wannagettachevy's Avatar
what lca's will fit my truck?
im going to cup some lca's and i want to find a used pair on cl! what years can i use without a balljoint or tie rod change on my 66? thanks homies!
wannagettachevy is offline   Reply With Quote
Old 08-15-2011, 12:40 AM   #2
Captainfab
60-66 Nut
Re: what lca's will fit my truck?
The C10 LCA's are the same from '63-'70.
Old 08-21-2011, 11:02 PM   #3
wannagettachevy
ok, and other years' lca's will still fit just require a balljoint swap correct?
Old 08-21-2011, 11:51 PM   #4
Rooster's 67
Rooster's 67's Avatar
CHEVROLET C10 1963-1970 are direct bolt in, 71-72 will require a ball joint change from factory installed. 63-72 all use shaft and solid bushings,
73-87 C10 or 73-91 R10 are a direct bolt in but will also require ballpoint changes, but they use the rubber bushings.
essentially any half ton two wheel drive control arm will "fit" just depend on what year as to whether ball joint change is required or not.
the correct ball joint for your application is a Moog K6023 Fits Applications
CHEVROLET BLAZER 1969-1970
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
