08-15-2011, 01:01 AM | #1 |
Does this combo sound like a winner?
Current: 283 with 4 speed manual, 4.56rear with 15" tires
Going to: same 283/4spd. Manual, 3.42 rear, 16.5" tires. I've yet to install the rearend, but I've got the quadrajet on my 283, hopefully with this ratio it'll cruise much better. Any thoughts? Posted via Mobile Device |
08-15-2011, 01:13 AM | #2 |
60-66 Nut
Re: Does this combo sound like a winner?
The 3.42 gears are a good highway gear, but yet are low enough to get rolling pretty good. Although with a 283, which don't develop as much low rpm torque as say a 350, you will need to watch your tire OD. Otherwise you may be slipping the clutch a bit to get going.
My suggestion would be to not go too tall of a tire. I would try maybe a 8.75 x 16.5 to start. Actually if you can find a set of 16" wheels, I would go that route. It is much easier to find 16" tires than 16.5's. Especially some used tires to try out before you spend the $$ on new.
08-15-2011, 10:20 AM | #3 |
Maybe I should stick with my 15" tires then until after the axle swap?
08-16-2011, 12:22 AM | #4 |
60-66 Nut
You've got 15's on there? Yes that wouldn't be a bad idea, until you get a better idea on a good tire OD to run.
08-16-2011, 04:39 AM | #5 |
I have 3.42's and 30.7" tall tires and it works perfect... I do have a bit more power though...
Perhaps a 30X9.50R15 tire (assuming your wheels are wide enough for that size tire)? |
08-16-2011, 08:21 PM | #6 |
