Old 04-08-2003, 10:58 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Question iNSTRUMENT PANEL LENS
Can someone tell me how to buff out the markings on a instrument panel lens so they can be redone.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-08-2003, 11:54 AM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
I'm not aware of anyway redoing the markings on the 67-72 instrument panel lens. However, using a soft cotton rag such as an old t-shirt and permatex plastic polish in the blue and white can, you can hand polish the lens and in 20 minutes worth of work mine looked like brand new. Polishing on the backside did not mess up any of the markings.
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 04-08-2003, 05:20 PM   #3
72BLAZERDUDE
Wasn't somebody reproducing the markings for lenses
Old 04-08-2003, 07:44 PM   #4
casey
casey's Avatar
1971lt1swbposi373, whats that stuff in the blue and white can called I'd like to get me some
casey is offline   Reply With Quote
Old 04-09-2003, 12:13 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some of the other members havve been using polishing compound on the lens and getting the numbers off...someone else waid he used a razor blade with no scars.
Old 04-09-2003, 01:01 AM   #6
1971LT1SWBPOSI373
Re
Casey.... It's Prematex Plastic Polish. You might have trouble finding it in a store, but you'll find it at any aero-club or airport that operates light aircraft. They use this stuff on the plastic windsheilds, and not only does it clean & polish well, it also will remove light scratches. In the case of our dash panel lenses, it is not abrasive enough to remove the markings. If you can't find any Casey then pm me and I'll get some to you. It works absolutely the best for quickly restoring the lens. TJ
Drinks Miller MGD
Old 04-09-2003, 03:14 AM   #7
Seke69
Space Cadet
Seke69's Avatar
hey TJ, is that stuff expensive?
I've been working on my Ins. panel lately too, I'm almost to the point where I'll just buy a new one.....
Seke69 is offline   Reply With Quote
Old 04-09-2003, 12:40 PM   #8
1971LT1SWBPOSI373
Nope, it's not very expensive, and a little goes a long way. For a lens job you would certainly use less than 1/3 of a baby food jar. Use it sparingly like you would a rubbing compund, no buffers. Your best bet would be to try some small local airport and tip the line boy to get you some, but take a baby food jar with you. You can buy the stuff, but then you'd have a lot left over. The plastic polish works great!!!! Mequiers also has some products out there that you can find in the wax section of auto parts stores. I have personally used these products on aircraft and I was not totally satisfied with the results. Permatex works!!!!!! Post a few pictures of your lens when your done! TJ
Drinks Miller MGD
Old 04-10-2003, 09:19 AM   #9
casey
casey's Avatar
My neighbor works for flight craft I'll ask him if he can get this stuff, if not I might tap on you for some thanks TJ
