Old 08-15-2011, 09:31 AM   #1
vtwinsport
vtwinsport's Avatar
77-80 pulse wipers- whats your switch do?
Hey all,
I need to ask those with intermittant wipers on trucks between 77-80 only; what happens when you move your switch to the right?
example- left is off, 1st right is delay, 2nd right- slow, 3rd right - fast, push to wash.
I want to know what the factory switch was set up to do?
Thanks in advance.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 08-15-2011, 09:56 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 77-80 pulse wipers- whats your switch do?
mine didn't come with that option but recently started working intermintantly
now i gotta hold the button in just to wipe lol
but that sounds right,turn the dial to set the delay
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-17-2011, 12:35 AM   #3
patmchicago
Mine's a 79 Big Ten and sometimes they turn on by themseves even when the keys not in or turned. Still haven't figured them out yet.
patmchicago is offline   Reply With Quote
Old 08-17-2011, 12:54 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
My '78 Silverado has the intermittents and they only work once every 8 months for about 6 seconds. I can't figure them out either.
Old 08-17-2011, 09:09 AM   #5
vtwinsport
vtwinsport's Avatar
Ha ha, same problem here. but how many positions do you have in the factory switch? does your switch move left at all?
Old 08-17-2011, 10:58 AM   #6
tucsonjwt
Don't know about your models, but on my 83 it is hold to the left to "pulse" the wipers (the wipers move as long as you hold the switch to the left). Moving the switch to the right is just low and high speed wiper. I never figured out what the dial with a white arrow is supposed to do, but I never saw an owner's manual either.
tucsonjwt is offline   Reply With Quote
Old 08-17-2011, 12:17 PM   #7
vtwinsport
vtwinsport's Avatar
the switch is supposedly different from 78-80 than anything from 81 and newer. I'm guessing it doesn't move left on teh 78-80.
The dial is to adjust the intermittant dealy from long to short (clockwise). Anyone have a manual?
Old 08-17-2011, 12:35 PM   #8
406 Q-ship
406 Q-ship's Avatar
I installed pluse wiper on my 74 from a 78 (may have been a 79). There is five positions. Starting from the left to the right:
1. Pulse wipe (momentary sprung position)
2. Off
3. Delay (here is where the dial wil change the wiper delay)
4. Slow speed
5. High speed
You need more than just the switch to make intermediate wipers work. It requires a wiper motor from a 78 late (there are early and late wiper motor) to 1980 truck wiper motor. Then it also needs the delay wiper module that plugs in the wiring harness off the rear of the wiper switch, between the harness and the switch.
If the wipers wipe without using the switch, it is called phantom wipe and the wiper delay module has gone bad. Mine does this when the truck gets jarred from a bump, but I am too lazy to replace the module. The module can be removed and wiring harness pluged directly into the switch and the wipers will operate in two speed mode only.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-17-2011, 12:35 PM   #9
bmchevy1979
bmchevy1979's Avatar
same here I just unplugged mine because I didn't use them enough at the to have it plugged in they would just run my battery down
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 08-17-2011, 12:40 PM   #10
bmchevy1979
Originally Posted by 406 Q-ship View Post
If you wipers wipe without using the switch, it is called phantom wipe and the wiper delay module has gone bad.
well that is good to know I think I will just eliminate the delay setup and put in a regular one I think I can live with it seeing as how I have driven my 76 with regular wipers for over a year
<Brandon>
Old 08-17-2011, 01:06 PM   #11
patmchicago
Thanks for the great information Q-Ship.
Old 08-17-2011, 06:45 PM   #12
vtwinsport
vtwinsport's Avatar
Great info- thanks.
That left position, do you you push in or push left?
Reason I ask Is I have a short in my cluster lights when I do that and I end up blowing fuses so I was wondering if the left position was from a switch from 1981 forward?
2. Off
4. Slow speed
5. High speed
Old 08-17-2011, 08:01 PM   #13
Corts60
Just here to tinker
Corts60's Avatar
You push it left, not in. Pushing the knob in will move it to the right and activate the washers. Mine is the same as Q-ships.
Old 08-17-2011, 10:33 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
fixed my probs , the back of the switch had come loose
inside a copper strip had flipped over too
one is even burnt shorter
now slight left it will swipe,when held
but i did stretch the spring a bit for more tension on the selector ball
when back together......no squirt yet but it wipes
John
Old 08-17-2011, 10:53 PM   #15
vtwinsport
vtwinsport's Avatar
Hey all,
Now that I know the 'Phantom wipe' is from the delay module, I thought i'd share the details and wiring diagrams of my 78 wiper upgrade in the 76. Its a long winded one, but your can read it here.
http://beerbreadbike.wordpress.com/2...he-way-how-to/
