Old 08-15-2011, 12:22 PM   #1
JohnyWard
14 bolt and a shackle flip, Flex and Driveshaft Questions.
So here is the situation:
I have a 14bolt and a DIY4x shackle flip on a 1971 blazer. It has a 6.2 diesel/ NV4500/dodge(ish) np208 and I know I need a new, custom drives shaft.
The TCase has the standard GM flange for a future EBrake and I know I want a CV style shaft. The 14bolt is a 1350 strap yoke.
If I measured everythin correctly, and I plan on doing it at least once more, then I only need about 1.5 inches of shaft play on compression max (ie the drive shaft would be flat and the axle tube contacting the frame) but I have NO IDEA how far down the axle will travel with the flip and stock springs. From what I understand, most rear shafts have 4" total slip in them, this should give me around 7" of droop.
So here are the questions:
Does anyone know how far down the suspension will droop?
What are people reccomendations for driveshaft manufactures?
And likely more Questions to come...
JohnyWard is offline   Reply With Quote
Old 08-15-2011, 10:12 PM   #2
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt and a shackle flip, Flex and Driveshaft Questions.
I see this place brought up alot tom woods custom driveshafts http://www.4xshaft.com/ i can't personally vouch for it but i do see it quite alot
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-16-2011, 10:26 AM   #3
greguw
If your doing a shackle flip should not drop , depending on the shackle length think you get 4+ from the flip .
Driveshafts I Like Tom Woods products but Jess from High Angle drivelines is the man .
Every build and every spring is going to be different , not a exact since , you could repak your springs or ad a add-a-leaf to firm it up .
You will have pinion angles to consider ...
greguw is offline   Reply With Quote
Old 08-19-2011, 04:15 AM   #4
1malo68
1malo68's Avatar
Jess at High Angle can answer all of your questions (530) 877-2875
1malo68 is offline   Reply With Quote
Old 08-20-2011, 01:03 AM   #5
67_SS396
Each rig is different when it comes to droop. I would call Tom Woods before I called Jess, but that's just my opinion. Then again, I build my own drive shafts too.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
