08-15-2011, 12:30 PM | #1 |
Fuel tank from a JEEP
Hi, I saw a thread the other day (forgot to bookmarket it), where this guy uses a tank from a JEEP is a 15-16 gallon tank, does any one remembers the thread, I am looking for the year and model of the jeep that tank came from, he was also doing an engine swap, so the tank has a baffle.
Thanks |
08-15-2011, 05:05 PM | #2 |
Who Me?
Re: Fuel tank from a JEEP
((( crickets chirping )))
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
08-15-2011, 09:23 PM | #3 |
Don't know the thread, but I do believe that just about any YJ, TJ, or LJ tank would work with minor modifications for hangers.
Posted via Mobile Device |
08-16-2011, 12:42 AM | #4 |
60-66 Nut
Just be aware that the Jeep sending unit won't work with your original gas gauge.
08-16-2011, 12:45 AM | #5 |
it was a late 90s jeep Cherokee but its very deep in raising the floor in the box
08-16-2011, 12:49 AM | #6 |
this is the tank im using in my 62
08-16-2011, 10:29 AM | #7 |
Who Me?
Does that have the fuel pump in the tank?
08-16-2011, 10:31 AM | #8 |
The CJ tanks look like they might fit, but I don't have actual experience. I found a late 60's International Scout II tank that was a good fit for the rear rails (when I still had them)
08-16-2011, 11:35 AM | #9 |
thanks for your response. What tank is that S11Sean11, does it have an internal pump.
Thanks again |
08-16-2011, 06:36 PM | #10 |
08-16-2011, 10:41 PM | #11 |
08-16-2011, 10:43 PM | #12 |
08-17-2011, 12:40 AM | #13 |
08-17-2011, 04:39 AM | #14 | |
Thanks! |
08-17-2011, 12:48 PM | #15 |
Whoops - I was partially misinformed!
IT is from a Scout II, I had the year wrong! It is this tank: http://scoutparts.com/products/?view...oduct_id=10426 |
08-17-2011, 12:49 PM | #16 |
0-30 ohm output for the 66; I retrofit a 66 Chevelle pickup & sending unit to my scout II tank.
08-18-2011, 12:11 AM | #17 |
60-66 Nut
Yep, these trucks use a 0-30 ohm fuel sender. I don't know what ohm range Jeep is using on that application, but I am certain it is not 0-30 ohms. As an example, a '98 TJ uses a 220-20 ohms fuel sender.
08-18-2011, 01:25 AM | #18 |
i put a cj 7 tank in my 63 c-10 i pulled out the sending unit out of the c-10 & shortened it then put it in the cj tank works great also put the gas filler neck behind the drivers taillight
08-18-2011, 10:58 AM | #19 |
mater63, I'd like more info and some pix of your set-up if possible?
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
08-18-2011, 02:08 PM | #20 |
Resident Photoshop Nerd
Sounds like it might be the 'coffin' from the FSJ's -- something like this:
[LINK] I might want to read the thread first.. nvm. <_<
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
