Old 08-15-2011, 12:42 PM   #1
Rich916
Rich916's Avatar
Cracked Exhaust Manifold
Noticed some crakes in the manifold. I’m aware of different putty’s and fillers for fixing cracks but have no experience with them or even if they work.
Is this fixable or should I look for another Mani?
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 08-15-2011, 01:04 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Cracked Exhaust Manifold
I'd look for another one. The location of the crack would be difficult to keep it sealed with any kind of epoxy. You have a lot of heat at that point and also vibration from the exhaust pipe. An epoxy would probably hold for a few days- maybe.
You could take it in to see if an experienced cast iron welder can weld it but I suspect the cost would be greater than a replacement. And, be aware that if you take it in for repair you may have to replace it anyway if the repair is not done right.
68gmsee is offline   Reply With Quote
Old 08-15-2011, 01:17 PM   #3
mbgmike
New one, throw that in the scrap bin
mbgmike is offline   Reply With Quote
Old 08-15-2011, 01:55 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The Ram-horns are not hard to find... new and used. I would ditch that one.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-15-2011, 02:41 PM   #5
Rich916
Rich916's Avatar
Pretty much what I thought, I’ve seen different products for this type of repair. Just wanted a second opinion.
Old 08-15-2011, 08:49 PM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I'd weld it. Why spend money on a new one when you can spend a few bucks on some nickle welding rods? If it doesn't work out, your not out much. Its worth a try for sure.
Drill the top end of the crack to keep it from spreading, V the crack out, preheat w/a torch and weld it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-15-2011, 08:51 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i concur
cast iron welding is expensive and dangerous
scrap that exhaust
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-15-2011, 10:34 PM   #8
Lee H
Lee H's Avatar
Exhaust manifolds are cheap. Welding them never lasts long. I'm sure someone will chime in and say they welded one 29 years ago and it's still fine. Cut your losses and find a good used one.
Lee H is offline   Reply With Quote
Old 08-16-2011, 07:32 AM   #9
MagmaJct
MagmaJct's Avatar
I recently replaced my passenger side manifold because of a split up the center. Price from an eBay vendor wasn't too bad, around $45 if I remember correctly.
The only problem is it had ports for the AIR pump (which my truck doesn't have.) I had to find iron plugs from Home Depot to plug them. I used POR 15's exhaust grey paint and brushed it on.
Now the driver's side is leaking. Good time.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 08-16-2011, 07:43 AM   #10
mrein3
mrein3's Avatar
If your dead set on keeping an old cast iron manifold, my welding instructor outlined pretty much what Bust Ted Knuckle said.
***I've never tried this***
Heat up the piece with a torch. Weld the crack with high nickle rod. Bury the piece in sand so it cools down slowly or keep it warm and slowly bring the temp down using your torch.
Again I've never tried this or have ever seen it done. It is just what an old timer conveyed to me in a classroom setting.
Personally I'd find a good used one without the AIR ports in it.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-17-2011, 04:05 PM   #11
68 IRON
68 IRON's Avatar
Looks like it could be repaired...I think its worth a try. L6 manifolds arent everywhere any more. Repair and look for a replacement...someone here has one. Thats not a crack at the webbing is it? Might check for more cracks.
68 IRON is offline   Reply With Quote
