Old 08-15-2011, 01:21 PM   #1
50bomb
50bomb's Avatar
intake manifold?
Guys and gals? I am having trouble finding a carburator to fit on my late 70's sbc 350. I bought the engine/trans rebuilt just needs finishing on the outside parts. the intake manifold is a edlebrock performance rpm. I bought a useable carter 650 that supposely would fit but didnt and I could get my money back the guy said. Next I got a free rochester carb from a friend and also a 4 barrel and with adapter that i tried with and without on both carbs. Nothing lines up. I do not want to spend hundreds on a carb. So I most likely need another manifold? so I do not spend $300 on a carb.
I could not take picture of other setup because I have limited camera use. and leave comments. Ima poor boy and giving my all to build my truck. Its what make life better in a sick way haha.here is some with the carter 650 carb.
50bomb is offline   Reply With Quote
Old 08-15-2011, 01:24 PM   #2
50bomb
50bomb's Avatar
Re: intake manifold?
with the carter 650. None pictures of rochester but does not work either. I rather not look for an adapeter anymore. Those things suck. Ima sucker for old chevy trucks. Taking up my whole life. hahaa but soooo worth it in the end with the headaches gone.
Old 08-15-2011, 01:54 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That is a very old Carter AFB carb. Prolly came stock on a Pontiac or Buick. Get one of the newer AFB's or one of the Edelbrock carbs (just like the newer AFB's). Or a Holley square bore carb like an 1850 series in 600cfm.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-15-2011, 02:04 PM   #4
50bomb
50bomb's Avatar
Cool..I will ask my friend. He did hava a holley but not sure what size.
Old 08-16-2011, 07:13 PM   #5
50bomb
50bomb's Avatar
I think I am gonna try to sell the intake manifold to get a older one or one that will work for a rochester quadrajet I have. I think it maybe better anyways.
Old 08-16-2011, 07:56 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I gotta factory intake manifold id part with if ya looking for one. Whats wrong with your carb>?
John
1999 Toyota Tacoma 4x4
Old 08-16-2011, 08:07 PM   #7
50bomb
50bomb's Avatar
BOth carbs suppose to be good. the intake manifold is the problem. its to wide. I am not pay $200 or 300 for a carb. That just ridiculous. I had a rebuild carb on a 64 chevy truck i owned and they rebuilt it for $90 and was good for 6 years. Thanks for offer but gonna look around Oc/la/riverside area. Should not be difficult to trade this for something that works for me. This is a new manifold never used. I bought this 350 rebuilt. Always one thing after another. This is my last project for a llllloooonnngg time if ever again haha. tired
Old 08-16-2011, 08:34 PM   #8
rpmgroup
I have a GM cast stock manifold which uses a quadrajet, FREE if you want it. I am down by Lake Elisnore.
rpmgroup is offline   Reply With Quote
Old 08-16-2011, 08:42 PM   #9
vectorit
What?
vectorit's Avatar
Best set up for that is the new Edlebrock performer carburetor IMO.
I bet the next time you will do a little Google work before you buy another expensive part eh?
Simple look up of that manifold from the manufacturers website would have led you in the right direction before spending money.
I see those Edlebrock carbs for sale on this site all the time, and they usually go pretty cheap. For an everyday kick around set up, you can't beat that carb since it is basically bolt on and go.
That old Carter, I would take down any numbers on it and advertise it for sale someplace. Since someone is usually looking for the original or period set up for their project, and hopefully you can recover the money you spent on it.
Not that anyone here has ever purchased an expensive part, only to find out that they got the wrong thing for what ever reason - nope, never happens! yea right.
It's all a learning experience, and the trick is to learn as cheaply as possible.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-16-2011, 08:53 PM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
If you feel like making a trip out to Moreno valley i can help you with carb and Intake I'm in the scrap and salvage business Get a lot of engines with the Edalbrock newer intakes there used And i got a lot of Holley carbs that would work I'm more for the edalbrack 1406 its a 600 CFM carb very little hassles 951-242-4716 Sam i checking now i found one intake and a few holley carbs need to put the numbers up most of them are smog carbs from 1970--83 off the 460 and 454 chevy trucks and not much into holley
stsalvage is offline   Reply With Quote
Old 08-16-2011, 10:07 PM   #11
50bomb
50bomb's Avatar
Thank you all so much for helping me. We all know how great this site is. Pm sent to "rpmGroup" your not to far from me. Plus I got some fam there i need to visit. Thanks all..I will let you guys know what happens
Old 08-16-2011, 11:45 PM   #12
BIGKEV
You could always use an adapter! http://www.summitracing.com/parts/SUM-G1401/ These also help with atomization by effectively lowering the split plenum.
BIGKEV is offline   Reply With Quote
Old 08-17-2011, 02:33 PM   #13
50bomb
50bomb's Avatar
Yea I tried one but nothing lined up right.
Old 08-17-2011, 05:45 PM   #14
BIGKEV
You tried an adapter? You should be able to go to your local DIY parts store and get an "any 4 barrel to any 4 barrel manifold" adapter for $20-30 that will work.
