Old 08-15-2011, 03:21 PM   #1
Low87
been here longer than Liz
Low87's Avatar
coolant leak under pass side dash
I've got coolant leaking from under the passenger side dash. If I fill the radiator, it will leak down to the level of the hose that runs from the top of the radiator to the firewall. This coolant leaks out under the dash, across the floor and out under the pass door.
I plan on replacing the heater coil, is there anything else I should look at?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 08-15-2011, 04:19 PM   #2
tucsonjwt
Re: coolant leak under pass side dash
Nope, AFIK, that is the only coolant item in that area.
tucsonjwt is offline   Reply With Quote
Old 08-15-2011, 04:26 PM   #3
juiceman650
juiceman650's Avatar
Yeap,that's about it.
juiceman650 is offline   Reply With Quote
Old 08-15-2011, 10:04 PM   #4
Goldfinger
Goldfinger's Avatar
That happens all the time with a clogged or damaged heating core. Depending on the shape of all your hoses i'd replace them while i was at it
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-15-2011, 10:51 PM   #5
tucsonjwt
Get a copper heater core, not an aluminum (usually aftermarket) one. If you can just hook the hoses together temporarily and wait a while, I would price a genuine GM/ AC Delco copper core from one of the online vendors. If it is not too much, I would go with OEM. This is one of those PITA jobs you don't want to do again if you don't have to, especially if you have A/C.
