08-15-2011, 07:41 PM | #1 |
HELP!! trying to rebuild a freefloating rear axle
I have a 1970 chevy 8-lug free-floating axle its a 4:56 posi, trying to rebuild the posi unit where can I find parts and anyone know what the backlash and clearances are suppose to be? and how can i convert it to accept dually wheels? any help would be awsome thanks guys
08-15-2011, 10:20 PM | #2 |
Re: HELP!! trying to rebuild a freefloating rear axle
By free floating do you mean full floating? http://www.pirate4x4.com/tech/billav...ble/index.html there's a big ol bible on them and as for converting to a dually i see some people just using a big spacer so both tires fit now i am not sure if thats the right way to do it but if so here's a link for an example hope it helps http://www.pirate4x4.com/forum/showthread.php?t=659176
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
08-16-2011, 08:31 AM | #3 |
I assume you have the factory No-Spin/Detroit Locker. You can get parts from Eaton dealers. www.eaton.com . The HO52 has a dual wheel cousin (HO72) with the same differential. The housing and shafts are shorter and brakes are different. But,I believe you could swap the outer parts (brakes/hub) from a dual rear HO72. If not,maybe Arrowcraft can help www.arrowcraft.com.
08-16-2011, 06:04 PM | #4 |
thanks guys both links are awsome I didnt know about the ho72 axle maybe I can find one in the bone yard and make 1 out of 2
08-16-2011, 07:36 PM | #5 | ||
At this point, it doesn't really matter...with used gears, you cannot change or "adjust" it now. Trying to "tighten-up" the backlash will absolutely destroy the ring and pinion....and create a howl in the process. If the backlash is already excessive, you need new gears to start with....and a professional to install them.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-16-2011, 09:25 PM | #6 |
Do we know that he doesn't have a Dana 60?
Is this a leaf spring or coil spring truck?
08-16-2011, 09:48 PM | #7 |
Pics of rearend in question are needed.
