08-15-2011, 09:00 PM | #1 |
Anyone around Austin, Texas......
.....want to help me re-jet a quadra-jet? Runs great, but is running rich, and I believe the carb is from a 454. It now sits on a 350. I'll provide Shiner, or beverage of choice, and some carne of some sort on the grill. I've worked on 1 carb, and promptly caught it on fire. I'm North of Austin about 30 miles, and East of Georgetown about the same. If there are enough people (or any) who want to play, we could make a wrenching session out of it.
Thanks.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
08-15-2011, 10:31 PM | #2 |
Re: Anyone around Austin, Texas......
You need to check what it's jetted and rodded at now. If you need to change it you need to match the jets and rods on the way down. You can't just change the jet or rod and have it work correctly. If that q-jet has the stock jets and rods it should be fine as is. If you post the number I might be able to find what it started out life as and what jets and rods are stock.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
08-16-2011, 12:01 AM | #3 |
I'll find the numbers for you tomorrow evening. Thanks. It runs great. good response, no hesitation, lots of power. Just smells rich.
Thanks.
08-16-2011, 09:29 AM | #4 |
Check your timing. If the carb runs good thats where I would start. Good luck.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
08-16-2011, 09:57 AM | #5 |
What makes you think it is running rich?
08-16-2011, 11:21 AM | #6 | |
08-16-2011, 04:55 PM | #7 |
I haven't got it back on the road yet. Was wrecked by PO. Side swiped. i have a thread in the 4x4 section. i'm ready to tag and inspect it, just don't want to be dumping more gas than it can use. I'll try to get the numbers off the carb if i'm home tonight.
08-16-2011, 05:14 PM | #8 |
Hello there neighbor,I live just outside of Austin on beautiful Lake Travis.I have a little carb experience and I'm confident we can change jetting to help you run better.I have a great deal of experience with putting down some Shiners and grillin carne.Sending a pm with my number,give me a call and I'll do my best to help
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
08-16-2011, 06:34 PM | #9 |
If your smelling a little gas I would bet its more likely to be heat soak with the Texas heat than running rich.
1970 GMC truck 1988 Harley 1200 Sportster |
08-16-2011, 07:54 PM | #10 |
I have a freshly rebuilt quadrajet sitting in my garage that has the same thing- runs, idles, starts all good- but ran rich on the small block that it was on. I tried 3 differnt needles, I got it to were it wasnt running rich but it ran worse. I just took the carb and factory aluminum intake off and replaced it with a Holley 670 and a cheap ebay polished Pro Comp intake. Now after a little tweeking on the Holley it runs great!
08-16-2011, 10:28 PM | #11 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-17-2011, 06:47 PM | #12 | |
08-17-2011, 06:50 PM | #13 |
Numbers on the carb....
17059520 2798 ccp This is a 67 K20, but engine is a 75 350 from a suburban. Thanks, all.
