![]() Join Date: Sep 2002
WTB: Rochester 2 barrel carb
Looking for a Roch 2 barrel carb in good working condition.
Would like one with a manual choke that I can bolt on and know it will work properly. Please LMK condition and price including shipping to 08753. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: WTB: Rochester 2 barrel carb
ttt
I have a Rochester two barrel that I just removed from a small block 400. Engine came from a '72 Caprice station wagon that I am using for a project. Has a divorced choke and is in excellent condition, but probably needs a kit from sitting inside for the last several years. I can get pictures if your interested.
Don
Thanks Don '57 Chevy Nomad '70 Buick GSX '72 Cheyene (Boys' truck) |
There are 2 different size bases on those. The small one was used on the 265-283. The larger one on the bigger/later engines. I have some of the smaller ones with manual choke. It would need to have a kit put in as they have been setting for a long time.
georgec2434@yahoo.com |
Thanks guys, need one for a 68 307, not sure of the base size.
If u could post pic and LMK price I would appreciate it. Thanks Scott
send me a pm I think have what you need
Looks like the other guys have what you really need, so I'm going to back off unless I hear differently.
Don
![]() Join Date: Apr 2001
I found a couple today too.... I also know of one I could get easily off of a 68 307... I am planning on heading up to take a look at it theis afternoon... lemme know if you want pics...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Mike, thanks for the pics. Would be great if u could take pic of the one on the 68 307.
The others look to be a bit rough and they dont have manual choke so will pass on those. Thanks Scott
Does the one you want have the fuel intake line in front like in the photos or on the side? I will get a photo of mine tomorrow.
The fuel intake is on the side.
I have one off a 70 307 if that will work?
was off my uncles 70 K30 he had up there in pennsville.nj ..lol I have the carb here thats all i have left. mabye it will go back north.. ![]() scott check these out,on a parts camaro i got...all 4 14 inch alum. slots... ![]() |
#13 |
Great, if u could post a pic I would appreciate it.
Gotta love those wheels. Scott
#14 |
#15 |
Think I found whatyour looking for.... off of a WA code 68 307 and OE manual choke.... lemme know if this is the correct critter... i did pull it but it was dark before I could get any off the truck pics...
--Mike PS.. was it you that needed a dipstick tube too???? I pulled that as well....
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's Last edited by tkeduk8r; 08-19-2011 at 12:41 AM. Reason: oops |
#16 |
still looking 4 a good running 2 barrel carb
#17 |
Just a Member
I have one but I am working out the kinks on it
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
#18 |
![]() Join Date: Nov 2008
Have one I took off my daily driver, man choke.
I removed to put a 4bbl on. I will post a pic tonight |
#19 |
sounds good, thanks
#20 |
was that one I pulled off the blue 68 a while back not going to work???? I still have it here if need be....
--Mike
#21 |
Mike, thanks for the offer but looking for one a bit cleaner.
Need one that came off a current runner in good shape. Thanks Scott
#22 |
![]() Join Date: May 2006
Got one you can have Scot
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#23 |
i still have the one off my 72 burb 307. it is hot air choke and includes the intake manifold. i threw a rebuild kit in it but i think it needs just a little tuning (not my forte) to run perfect. only been off the truck since spring 2010 when i switched to a Q-jet. $100 shipped to your door.
[IMG] ![]() ![]() |
#24 |
