Old 08-16-2011, 08:38 AM   #1
Robznob11
Robznob11's Avatar
brakes need help!
Does any one have a pic of the rear brake line setup on the axle. I need to make lines from scratch. I'm trying not to have to buy high dollar specialty pieces. Also will a disc brake proportion valve off a 73-87 work on a 71 setup those are some of the last pieces of the puzzle I'm trying to hunt down
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-16-2011, 01:11 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: brakes need help!
Unless you're trying to be period correct, I'd just make them to fit and not worry about the period correct bends, etc.. That's what I did on my 69. The important thing is making good end connections. You have to do it right.
I'll try to take a pic of my 68 GMC that still has the original lines but not sure how that's going to come out.
68gmsee is offline   Reply With Quote
Old 08-17-2011, 08:16 AM   #3
Robznob11
Robznob11's Avatar
What I'm trying to figure out is. Is ther a t that a hose connects to coming off the frame rail? Do both lines on eather side of the T need to be equal length and are they hard lined into the wheel cylinders. Thanks. Not trying for period correct
LED TAILS
Old 08-17-2011, 08:53 PM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The rear brake hose goes into a brass T fitting and then out to both wheels. The T fitting is secured in a metal tab that is welded or riveted to the frame. The lines are not equal length, no need to be.
Sorry no good pics.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
