Old 08-16-2011, 01:24 PM   #1
Northern lights
Gas tank relocation
It seems that relocating the fuel tank is one of the first things many people do with their vintage trucks. Sometimes it's done to make more room in the cab but most often it seems that people are doing it for safety reasons. I've always felt that, while behind the seat is perhaps not the safest place (IMO second only to between the frame rails in front of the rear axle), it is safer than behind the rear axle, where most people put it, hence the reason that I removed the underbed tank that was in my truck when I bought it and put it back behind the seat. I stumbled across this article that I thought might be of interest to those considering a tank relocation. http://www.autosafetyexpert.com/defect_fueltank.php
Northern lights is offline   Reply With Quote
Old 08-16-2011, 01:33 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Gas tank relocation
Good of you to post that. I like the part where GM paid a settlement to avoid a recall.
Old 08-16-2011, 03:23 PM   #3
pdxhall
pdxhall's Avatar
IMO this is a completely different situation than having the fuel tank in the rear of a truck. The drivers compartment is separate from where the fuel tank is, unlike that of a car. I'd much rather have it back there rather than sitting in the cab with me and still vulnerable to side impact collisions.
pdxhall is offline   Reply With Quote
Old 08-16-2011, 03:27 PM   #4
jimmydean
jimmydean's Avatar
I have a spare tank mounted on the driver frame rail under the bed (looks like a dealer type option). I am putting a fuel cell there rather than try to wedge it somewhere else.
Otherwise it will be in front of the axle under the bed.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-16-2011, 06:18 PM   #5
brap999
brap999's Avatar
I have a Summit fuel cell mounted in the rear between the frame rails. The reason I did this was because my old tank was rusting from the inside and eventually when I hit a hole in the road it was enough to cause it to leak all over the inside of the cab. Plus the filler neck has a tendency to come loose letting gas vapor out in the cab while I'm driving. That alone was enough of a safety issue for me to move the tank to the rear of the truck.
I agree that behind the rear axle isn't the safest place, but I feel it's safer than keeping it behind my seat.
The way I see it, if I get in an accident, or flip the truck, at least I don't run the risk of fuel getting all over me inside the cab. I'll take my chances in a rear end accident with the tank behind the axle over that.
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 08-16-2011, 07:41 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
We`re all rolling with a bomb, place it where ever it makes you sleep at night. I think in Losthope`s case he`ll move his to the rear on his next rig, he was awash in gas...really got lucky..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-16-2011, 07:47 PM   #7
Max1775
Max1775's Avatar
Trucks are worlds apart from cars and SUVs in this aspect. The cars and suv have a vulnerability that the passenger compartment or trunk (which is not separated from the cabin by a fire wall) is located directly over the fuel tank. This allows the fuel tank to push up into the floor and if both are penetrated there is a possibility of burning fuel inside he vehicle. This is not an issue with trucks unless you have a camper that is open from the cab to the bed.
Max1775 is offline   Reply With Quote
Old 08-16-2011, 08:31 PM   #8
losthope
losthope's Avatar
i was very lucky to walk away from that crash and lucky nothing sparked while i was pinned under dash,as the tow truck dropped the truck off in my pop's back forty the battery was shorting out shooting sparks everywhere,none of the rescue personal thought about unhooking battery i guess...back on topic my new rig has the stock tank behind seat i will use it to get truck running and then put it behind the rear axle as soon as its drive time....i figure theres more of a chance to survive pinned in the cab not covered in gas then with the tank behind seat soaked in fuel like i was.......i was just lucky.....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
