Old 08-16-2011, 03:36 PM   #1
losthope
losthope's Avatar
Enigine wiring harness's ????
ok guys i finally got the engine in the 66 and got some ?'s about the wiring harness's in the engine compartment..p.o cut all the wires at the firewall plugs when he removed engine can you tell me what wires are what?? i did a search and didnt see anything that helped.
drivers side firewall wiring harness:
#1 black wire?
#2 red wire?
#3 yellow wire?
#4 green wire?
i know the plug on top does hood turn signals.
engine wiring harness in middle of firewall:
#5 green wire and red wire in same plug port?
#6 wire under the green and red wires?
#7 wire all the way to the right of plug?
and should there be any other wires that are missing from the plugs??thanks for any info!
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-16-2011, 04:35 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Enigine wiring harness's ????
Internet is to slow here to send you a wiring diagram. If you go to the search box at the top of the page enter engine wiring diagram and click on the 67-72chevytrucks.com then Google all the previous threads with those words will show up. Pick and choose!
Old 08-16-2011, 05:13 PM   #3
jimmydean
jimmydean's Avatar
Here you go, I just did a bunch of rerouting and removing last weekend.
http://67-72chevytrucks.com/vboard/s...d.php?t=378484
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-16-2011, 08:41 PM   #4
losthope
losthope's Avatar
dang those wiring diagrams are confusing!!!! i'll try and decipher it again.. i guess i was looking for one of you guys to do the work for me and just tell me which one's go where!
Timmy D.
Old 08-16-2011, 10:48 PM   #5
jimmydean
jimmydean's Avatar
Well, it depends on what you are running, I guess. Do you have an internally regulated alternator? HEI or points distributor? I printed out the diagram and reworked my engine harness, so I can help if I know where you WANT them to go.
Let me know what you got and I will try and help.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-17-2011, 12:15 AM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here's a I6;
Here's the V8:
66 C20 Service Truck:
Old 08-17-2011, 12:32 AM   #7
losthope
losthope's Avatar
thanks guys for putting up with me, im running 350v8, Hei dizzy,and a one wire gm alternator......
Timmy D.
