resident wrencher
hood question
so my 1980 had the hood where above the grille part was raised ive seen a lot of these and think they are cool what years or options leves come its just the center section above the grille part inbetwee the lights thats slightly raised up from the rest of that part of the hood
#2 | |
Re: hood question
John 82 Chevy Silverado 350ci/TH350 ![]() |
resident wrencher
Re: hood question
was it somethign special about them or just the change for the last few years of the round fender
Re: hood question
It was just a style change. Engineeres cant seem to leave perfection alone.
Re: hood question
comparison pics? i have no clue what you guys are talking about
resident wrencher
Re: hood question
i think the rasied looks like its a hd thing on the newer trucks it looks cool too bad those hoodsare way weaker at he center
Re: hood question
They are referring to the design on the front of the hood on 73-76 (pic#1) the center bar or ridge of the hood goes all the way down to the grill on 77-80 (pic #2) the center bar ends and turns into a raised section across the entire front most portion of the hood
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
resident wrencher
Re: hood question
Yes the second hood just looks meaner to me i like it but it seems they are flimsy in design and thats a sik burb round fender dooly with a 7374 grille some one has my kinda style
Re: hood question
I may have been wrong. I think they started that hood design in 79 to go with new headlight bezel design. Used them on 1980 trucks too.
Re: hood question
It was 77 says it down near the bottom
resident wrencher
Re: hood question
Thank you very much guys you all are a greath help
Re: hood question
It was done as an aerodynamic improvement.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#13 |
Re: hood question
How do you get the hood to sit all the way down?
#14 |
resident wrencher
Re: hood question
What do you mean dmc
#15 |
Re: hood question
I mean, my hood is up about a 1" next to the cab. How do you get it to fit right? Can you see pic?
#16 |
Re: hood question
The brochure states '77 but it actually started in '79. '73-'78 hoods look similar from the outside but have a difference or two. One is the hole in the hood for internal hood release . I think that started in '77. The hoods are the same from '73-'76. The '77-'78 hoods look identical on the outside but have a different hole configuration for the hood latch assemblies because the internal release was an option. '79-'80 hoods have the raised lip design and the internal release hole .
Frank
Born and proudly residing in a Red State ! |
#17 |
resident wrencher
Re: hood question
no i cant see the pic if its up in the back try adjusting the hinges or eplace them with the springs if its up in the center your hood is bent aka chevyitis if its up in the front adjust the bumber and the latch
#18 |
Re: hood question
the hood is higher in the back, how do you adjust the hood?
#19 |
resident wrencher
Re: hood question
Losen the hood hinge and lower them losen it on the fender and push it down losen it so its still stiff but if you hit it with your palm is will move and close the hood with them lose and tap it doqwn and then open it and tighten once its where you want it
#20 |
yeller
Re: hood question
Thread hijack
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#21 |
resident wrencher
Re: hood question
Let him be
#22 |
Re: hood question
Can someone get a closer pic of that ridge in the middle of the hood? I'm repairing my hood and the one spot that has rust is right in the front of the hood. I can't tell if the ridge goes completely down or not. Hopefully it doesn't cause I'm going to replace the rust with some metal and if that ridge goes completely down I wouldn't know how to duplicate that ridge...
Thanks Slim Posted via Mobile Device
Long live SLIM ------------------ At least try to buy American ![]() |
#23 |
Re: hood question
I don't know if this helps but here is a direct front view of my truck. 77
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
#24 |
Re: hood question
That definitely helped... Thanks. I have no clue how I'm going to duplicate that ridge. I might have to start searching for another hood now
#25 |
78K & 79C Jimmys
Re: hood question
my 78 red,my 79 black
78 external release 79 internal...wana put it in the 78
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
