Old 08-16-2011, 11:38 PM   #1
Joe Blaze
Numbers stamped onto frame rail '71 Blazer
can anyone advise what the numbers stamped in the side of the frame rail just under the drivers side floor area mean? i just saw them today while i was under there. The last digits almost look like a date.
Joe Blaze is offline   Reply With Quote
Old 08-17-2011, 12:35 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Numbers stamped onto frame rail '71 Blazer
The are part, if not all, of your VIN.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-17-2011, 01:14 PM   #3
29od1
I don't know about the side of the frame, but the partial VIN will be stamped on top of the frame rail under the drivers side. You can't visually see it unless the tub is off or you use a mirror.
I think this may be a material spec number for the raw material before forming?
29od1 is offline   Reply With Quote
Old 08-17-2011, 02:20 PM   #4
Joe Blaze
Mystery solved. I googled the number, and it came back with a post on this board from 2002 by Huck, with the same partial number on his frame.
http://67-72chevytrucks.com/vboard/s...ad.php?t=14308
It looks to be a part number related to the frame rail.
