Florida Edition
![]() ![]() Join Date: Oct 2010
Odd frame rail stamping numbers?
The first pic is of a 69 Chevy SWB 1/2 ton
The second is a 70 GMC LWB 1/2 ton....the 58131 matches the last 5 of the vin. Whats up with the S prefix? Are all GMC's different like this?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: Odd frame rail stamping numbers?
Good question. I'm curious to now the answer.
My '71 GMC has a letter before the 6 numbers that match the VIN, but it's a J not an S. I thought that meant where it was made?
Florida Edition
Here is the whole GMC VIN CE134-SZ58131
I believe the prefix (S) is the mfg plant...St Louis C=2WD E=V8 1=1/2 TON 34=FLEETSIDE S=ST LOUIS Z=1970 58131= 8131st truck built So.....GMC only stamped the Plant and the build number? This truck seems to have been an oddball anyway....1/2 ton FACTORY BIG BLOCK A/C 6 lug CST 127", with aux fuel tank switch in the floor (exactly the same as my 72 Custom Camper). The tank was gone but the mounts were still there, this is where it gets strange...the hangers for a tool stowage box were still mounted to the bed floor but that bedside had been replaced. Leads me to believe it was a Custom Camper but there were only 3 holes in the door above the door handle for the Custom emblem, no Camper emblem. Did they even make a 1/2 ton Custom Camper? BTW instead of a SPID I got a chrome glovebox door.
Florida Edition
More info on this...
The GMC S 58131 breaks down like this: S=St Louis the (5)XXXX denotes 1970 only. 68,69 & 71 begin 10001 and 72 begins 500001, this comes from LMC's catalog (for what thats worth). So I can tell it was made in St Louis in 70 and was the 8131st truck built. What it doesn't tell me is if it is a 1/2 or 3/4 ton frame. The VIN tells me it's a 1/2 ton. I read some old threads about different steel thicknesses between 1/2 and 3/4 tons, according to the above info there is no difference on GMC's. I have answered all my own questions except WHY SUCH A DIFFERENCE BETWEEN CHEVY AND GMC STAMPINGS? And if the build number was (1)XXXX how would you know if it was a 68, 69 or 71? ![]()
Florida Edition
Any more thouhgts on this?
I don't believe a longbed 1/2 frame is any different than a 3/4t. One frame would be strong enough for the difference is GVW,which isn't very much. The springs and axles are enough for that.
In '69 there were Custom Camper/10s. I'm not sure about '70. I know in '69 a factory auxiliary tank was offered and was located in the rear,not the side. I have only seen '72s with the driver side tank. But,I have a '71 Custom Camper brochure that lists the auxiliary tank as a suggested option. But,it's not offered in the dealer data book. The tool & stowage compartment has nothing to do with the Custom Camper option. They were available on any longbed.
Florida Edition
Thanks Tim, I'm still confused about the build sequence numbers..
I have answered all my own questions except WHY SUCH A DIFFERENCE BETWEEN CHEVY AND GMC STAMPINGS? And if the build number was (1)XXXX how would you know if it was a 68, 69 or 71? Also were all big block 70 GMC 1/2 tons 6 lug? Seems that there is a limited amount of build data for GMC's compared to Chevys. Thanks, Brad
Roadtrip!
![]() Join Date: Feb 2003
Any 1/2 ton 2wd from 67-70 would be 6 lug originally. Any 71-72 1/2 ton would be 5 lug. Shouldn't matter if gmc or big block or not.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Vintage 4x4s
I'll look at the stamping on the frame from a 69 GMC BB C20 when I get home.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#11 | |
Florida Edition
Any info on the stamping numbers?
Florida Edition
Let me know what you find. I'm very curious about all this.
#13 |
Vintage 4x4s
They match on my 69 GMC BB C2500:
stamped on frame: SA29914 last 7 digits on title: SA29914 It seems like they forgot to stamp the Z on your truck.
