Old 08-17-2011, 08:47 AM   #1
kcfirstbuild
2'drop coil question.
Will I have any problems putting in my new front coil springs, they are 2" drop springs. I Don't have any weight , its just the frame. I Figure since they are 2" shorter they should go in with out any problems. I have the control arms on and ready to go for this weekend.
kcfirstbuild is offline   Reply With Quote
Old 08-17-2011, 09:09 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 2'drop coil question.
We did when we put coil springs in the front of my truck. We ended up putting 2 concrete blocks and two people on the frame to hold it down.
Later I read a post where you can run a chain under the floor jack and up and over the upper control arm and when you jack it up the chain will pull things in place. I have never tried this method yet so I am not sure about how it all works.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-21-2011, 12:04 AM   #3
kcfirstbuild
Is engine weight alone enough to jack up the lower control arm to install the spindle ?
Old 08-24-2011, 07:49 PM   #4
kcfirstbuild
bump ?
Old 08-24-2011, 08:41 PM   #5
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=18305
Read this thread. Bolt the a-arm crosshafts in place, without springs. READ AND LEARN!
Good luck.
TobyArnot is offline   Reply With Quote
