Old 08-17-2011, 01:40 PM   #1
dmcclanahan
Ground cable
My son is 3yr old and helps me when i work on the truck. I dont want he grabing the ground cable, that is located ont the alternator backet, is there another good place to relocate it?
dmcclanahan is offline   Reply With Quote
Old 08-17-2011, 01:56 PM   #2
bmchevy1979
bmchevy1979's Avatar
Re: Ground cable
mine is grounded to one of the holes on the frame rail but you have to make sure you have a good ground from the frame to the motor also
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 08-17-2011, 01:58 PM   #3
kris's66lwb
resident wrencher
Re: Ground cable
Why are you afraid of it ? It wont shcok him i grab mine all the time with wet hands the only thing to worry about is shorting something out to the terminal on the starter sol or the stud on the alt on hte back to some thing grounded it will arch and heat up and possably weld the metal to it
kris's66lwb is offline   Reply With Quote
Old 08-17-2011, 11:11 PM   #4
67_SS396
Re: Ground cable
Move it down lower to the head or block. That's a better ground location anyway.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
