Old 08-17-2011, 06:11 PM   #1
Groyd
Groyd's Avatar
What is this plug?
I've got both plugs already on the passenger side of the tranny and can't figure out where these two go. Any suggestions? I only recommend tranny, because the tape marking that came on them says tranny1.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 08-17-2011, 06:22 PM   #2
mighty_mike015
Re: What is this plug?
I think those go on the driver side of the trans where the shift lever is. On the electronic transmissions there is a plastic box that slides over the shift lever shaft and I believe it outputs to the ecu and dash to say what gear the trans is in. I'm out of town during the week so I can't run out to the garage and check to be sure, sorry.
Mike
mighty_mike015 is offline   Reply With Quote
Old 08-17-2011, 10:30 PM   #3
eagleuh1
eagleuh1's Avatar
Whats the harness from? Year? What are the colors of the wires in each plug? Jim
eagleuh1 is offline   Reply With Quote
Old 08-18-2011, 12:17 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
i think mike is right. It plugs into the plastic peice that slides over the shift selector shaft.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-18-2011, 07:40 AM   #5
CamaroChris
It goes on the driver side gear selector. It cream color plug is the neutral safety switch the gray is unknown I have been looking for info on it for two weeks.
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 08-18-2011, 08:50 AM   #6
Groyd
Groyd's Avatar
Mike
I think you're right. I might have removed that when I put on the lokar shifter. I'll check when I get home tonight.
1957 Chevy 3200
Old 08-18-2011, 02:29 PM   #7
Puropedo
Hey guys, does someone know if its required to use those connectors and or the "plastic box" on the tranny shifter when youre doing an ls/4l60 swap? Ive read in some websites people saying you have to and others saying you dont...??????
Does someone here know for certain?
Puropedo is offline   Reply With Quote
Old 08-18-2011, 09:57 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I was told you don't need the gear indicator; the trans uses the vss to decide which gear to be in.
Old 08-18-2011, 10:24 PM   #9
Robznob11
Robznob11's Avatar
I think those are for a transfer case I know you dont need them for the tranny to operate. the main one is the round one and two long black ones don't know what they are for but the round one is what makes it tick. I remember cutting some plugs like that off when i reworked my harness. but it came from a 4wd truck. lt1swap probably has that plug identified
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-18-2011, 10:44 PM   #10
Groyd
Groyd's Avatar
Mike was right. I dug around and found the old gear shift indicator. Here is a pic of it and how I replaced it. I used the Dakota Digital Gear Shift indicator. I guess we'll see if it works?
1957 Chevy 3200
