Old 08-17-2011, 06:52 PM   #1
wpotter
wpotter's Avatar
87 Pick up & 87 Suburban Info Needed
I am looking to do a swap between a pick up and a Suburban. Can any tell me if the engine, trans, computer and wiring are the same between the two. I have a 87 truck that has been sitting for about ten years because the tranny went bad and can get a running Suburban that has a good engine, trans and several other parts. I know most will interchange just not sure on the fuel injection part of it. Any help will be appreciated, Thanks.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 08-17-2011, 06:57 PM   #2
Jonboy
Slots go on anything!
Re: 87 Pick up & 87 Suburban Info Needed
Engine, trans, computer should be the same. The fuel system will be similar as far as teh throtthe body and flexible fuel lines, from there the pickup and Sub lines are different. The sub hs a rear mounted fuel tank, while the pickup has saddle tank (or tanks).
1974 Jimmy- 5.3/4L80e/NP241
Old 08-17-2011, 07:02 PM   #3
wpotter
wpotter's Avatar
Thanks Jonboy. I can probably use the original lines for the truck, it has dual tanks.
Old 08-17-2011, 08:46 PM   #4
Goldfinger
Goldfinger's Avatar
everything should swap over bersides the tbi pieces. they can be made to work though
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-18-2011, 01:16 AM   #5
wpotter
wpotter's Avatar
Do you know what parts may be different? This is my main concern, tbi sensors and fuel injection. I want to keep it original looking or as close as possible and I would have both complete vehicles.
Old 08-18-2011, 07:21 AM   #6
Goldfinger
Goldfinger's Avatar
i just realized 87 was tbi for all trucks. so it will swap over easily as they use the same unit providing the engine and trans are the same as what was in the 87.
Old 08-18-2011, 08:26 AM   #7
Greenlee
Greenlee's Avatar
I'm doing the same thing. I'm using a 90' burb with an 87' truck. Everything so far has been virtually identical. My burb has the serpintine belt set up, so that's a little different. I swapped the the sepintine setup to the truck last weekend. My next step will be the wiring.
Greenlee is offline   Reply With Quote
