08-17-2011, 07:49 PM | #1 |
Who makes the best tool for installing solid rivets on crossmembers etc.?
Hello,
Started restoring a 71 GMC SWB 4x4. Having the frame powder coated. I am going to remove the rear leaf spring mounts cause they have swelled out some. I would like to keep it looking original as possible. Looking to buy the rivets and tool for installing them. Thanks, Mike Last edited by 67-72trucks; 08-17-2011 at 07:52 PM. Reason: typo |
08-17-2011, 10:03 PM | #2 |
Firefighter
Re: Who makes the best tool for installing solid rivets on crossmembers etc.?
Check these guys out.
www.bigflatsrivet.com
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
08-17-2011, 10:04 PM | #3 |
I would think the factory assy manual may give you a rivet diameter for the replacement. As far as rivet guns without spending serious coin do a search on ebay for rivet guns. Another is to find someone up around Seattle area go to a local pawn shop for decent deals on rivet tools and rivet heads for what you need. Pawn shops where Boeing or similar manufactures build aircraft. Most folks don't replace the rivets and just use grade 8 hardware but your set on returning to original. New rivets guns can run into a couple of thousand dollars used ones in working order hundred or two. A have a couple rivet guns quality names that I bought several years ago used and still work fine. Good luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-17-2011, 10:38 PM | #4 |
Thanks!
Anyone interested in selling there used rivet guns? Have any rivets left over? |
08-18-2011, 06:15 PM | #5 |
ttt
08-18-2011, 09:15 PM | #6 |
Grandpa in the rustmobile...
Set on rivits huh? Good luck I hate grinding them!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-18-2011, 09:56 PM | #7 |
A pneumatic rivet squeezer. After getting it set up using some scrap metal, just stick the rivet in, pull the trigger and it makes a nice bucktail.
08-18-2011, 10:48 PM | #8 |
Here is a thread ,we asked about the rivets.
http://67-72chevytrucks.com/vboard/s...d.php?t=464109 Scott
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
08-19-2011, 12:27 AM | #9 |
Active Member
I replaced rivets on my front spring perches on my 72 4x4 short wheelbase. I got the rivets from bigflatsrivet.com. The folks their are very helpful. Their catalog has a whole section on how to install rivets. I bought a tool from them that fits an air chisel gun. you have to cut the rivet to the right length then heat it red hot. You place it in the hole use a backup tool and round the end with the air gun and the riveting tool. I got very good results
Here's some pictures. |
08-19-2011, 12:29 AM | #10 |
Active Member
I replaced rivets on my front spring perches and on some cross members on my 72 4x4 short wheelbase. I got the rivets from bigflatsrivet.com. The folks their are very helpful. Their catalog has a whole section on how to install rivets. I bought a tool from them that fits an air chisel gun. You have to cut the rivet to the right length then heat it red hot. You place it in the hole use a backup tool and round the end with the air gun and the riveting tool. If the rivet cools off too much you just reheat it again and hit it again with the rivet tool.I the rivet rounding tool is not all that expensive. got very good results
Here's some pictures. Pictures are not too great but the results were satisfactory. Last edited by 72swbcamo; 08-19-2011 at 12:37 AM. |
08-19-2011, 12:44 PM | #11 |
Nice Work!
08-22-2011, 05:00 PM | #12 |
what length rivets did you guys use? Thanks
08-23-2011, 09:34 PM | #13 |
ttt
