Old 08-17-2011, 10:03 PM   #1
hex7f7f7f
What does this knob do?
The title should imply that this question is probably going to be stupid...
To the right of the ignition in my 66 c10 there's a knob exactly like the wiper knob. It's not connected to anything and there's so many loose wires under the dash (p.o. put in a lot of wire mess with the speaker/stereo/misc. accessories and then seems to have painted them all black...) I'm not sure which, if anything it should connect to.
Owners guide says it's a "Cigar Lighter (when used)", but I don't see how this knob would be that. Should this knob even be there? I'm tempted to just pull it out.
66 Chevy C10 Stepside SWB - Hope I don't screw this up too badly...
hex7f7f7f is offline   Reply With Quote
Old 08-17-2011, 10:06 PM   #2
BMERDOC
BMERDOC's Avatar
Re: What does this knob do?
A pic would get you more attention. I don't know if its factory or an add on.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-17-2011, 10:10 PM   #3
hex7f7f7f
woops. knew I was missing something
It rotates left and right with the little button in the middle that rotates it back to center. Doesn't pull out or push in at all.
Old 08-17-2011, 10:13 PM   #4
blackedoutharley
Looks like somebody installed the wiper/washer switch in the location originally reserved for the cigarette lighter.
Switch layout going from left to right should be:
Headlights
Wipers
Choke
Ignition
Cigarette lighter
blackedoutharley is offline   Reply With Quote
Old 08-17-2011, 10:15 PM   #5
hex7f7f7f
So it's probably just a placeholder then? Everything else is where it should be, including the working wipers knob on the left.
Screw it, I'm just gonna pull it out then.
Old 08-17-2011, 11:23 PM   #6
erock805
erock805's Avatar
could be the turbo timing retard...
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 08-17-2011, 11:30 PM   #7
brap999
brap999's Avatar
Do not push that button! http://youtu.be/kfj0sRiEqx4
Seriously though, if it only goes left or right, sounds like a wiper motor switch. Why would there be two? Who knows, maybe just to fill an extra hole left by a broken lighter?
1963 Chevrolet C10 Stepside
1972 Pontiac GTO
1998 Dodge Viper GTS
1999 Jeep Cherokee XJ
2018 Chevy Camaro ZL1-1LE
It's never too early to beef up my obituary
brap999 is offline   Reply With Quote
Old 08-17-2011, 11:33 PM   #8
hex7f7f7f
That's what I'm thinking at this point. There's also a toggle switch that looks like it used to control the horn (which is missing) and a number of other random additions that don't seem to do anything anymore so I dunno. Just trying to clean up the mess
Thanks everyone for the input.
Old 08-17-2011, 11:37 PM   #9
losthope
losthope's Avatar
i really wouldnt push that button....
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-17-2011, 11:55 PM   #10
jocko
jocko's Avatar
i'd only push it if it rains...
Old 08-18-2011, 12:45 AM   #11
blackedoutharley
My wife says I seem to like pushing buttons..... I'd do it just for spite!
Old 08-18-2011, 10:03 AM   #12
erock805
erock805's Avatar
Id push it but not inhale.
Old 08-18-2011, 10:26 AM   #13
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I'd push it to the limits.
There is a plastic block off plug for that opening when no cigarette lighter was optioned. Others have used the opening for the Signal Stat hazard switch. Casco manufactured the lighters for GM. I've seen two versions, one with a light to illuminate the housing when the lighter is removed and one housing without the light.
Old 08-18-2011, 10:32 AM   #14
Blue Heeler
Blue Heeler's Avatar
It's a nipple switch touch it and see if it works?
Blue Heeler is offline   Reply With Quote
Old 08-18-2011, 11:24 AM   #15
mweishaa
I'd leave it, having a button there would look better IMO than having a blank. If there's an actual switch there, you could see if it works.. and find something to hook it up to... interior light, a buzzer (for fun), neon underdash lighting (kidding), or something creative. Put a little label under it that says "eject".
mweishaa is offline   Reply With Quote
Old 08-18-2011, 11:37 AM   #16
Joe Blaze
It would be a windshield wiper switch and that button would be the washer fluid switch. it was a common setup on older style cars.
Joe Blaze is offline   Reply With Quote
Old 08-18-2011, 11:49 AM   #17
61TWUK
61TWUK's Avatar
thats what I was thinking
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 08-18-2011, 11:51 AM   #18
padresag
perhaps he installed an after market w/s washer pump and installed that switch to activate it. just check it out for w/s washers
ron
padresag is offline   Reply With Quote
Old 08-18-2011, 12:13 PM   #19
Joe Blaze
http://www.brotherstrucks.com/prodin...number=WWS0067
Old 08-18-2011, 01:21 PM   #20
jimmydean
jimmydean's Avatar
Originally Posted by erock805 View Post
could be the turbo timing, retard...
No need for name calling.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-18-2011, 01:23 PM   #21
hex7f7f7f
This switch had no wires attached. I did find the wire for the cigar lighter tucked up and taped away under the dash. Since the wiper switch on the left works just fine I went ahead and I swapped this switch out this morning
Needs cleanup, but it'll do for now.
Old 08-18-2011, 02:51 PM   #22
padresag
that is the signal stat 103 0r 105 switch for 4 way flashers, but there should be a wiring harness with it that connects into your wires that come out of the str column
ron
Old 08-18-2011, 03:09 PM   #23
hex7f7f7f
ron
That's what I swapped into it
Old 08-18-2011, 03:15 PM   #24
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great idea.
66 C20 Service Truck:
Old 08-18-2011, 03:33 PM   #25
monolith
Zero Albedo
monolith's Avatar
That was the Hyperspace button.
I like your arrangement a lot better.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
