Old 08-18-2011, 02:31 AM   #1
darkone
Proportion Valve Required for upgrading to power brakes?
hey all, im about to add a power brake setup to a 70 chev c20 without power brakes. my question is, will the existing proportioning valve on my non power brake system work? or do i have to get a new proportion valve? also, is there a suitable solvent a guy can use to clean out the power brake unit? thanks in advance for any input.
darkone is offline   Reply With Quote
Old 08-18-2011, 02:37 AM   #2
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: Proportion Valve Required for upgrading to power brakes?
The prop valve should be fine. They just make a difference between drum/drum and disk/drum trucks. I assume you're staying drum/drum, and just adding a booster. As far as cleaning the booster out, I'm not too sure. I'd be a little leery of some solvents when cleaning it though. You don't want something that'll eat the rubber parts inside it though.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-18-2011, 07:24 AM   #3
cdowns
cdowns's Avatar
drum/drum brakes do not have a proportioning valve// they have a simple distribution block only
Old 08-18-2011, 12:52 PM   #4
Stricklinator
Stricklinator's Avatar
I ordered a new distribution block from GMCPauls for my 1969. Seems strange that it would distribute two brake lines into two brake lines. Maybe it's there for the brake warning light switch?
Paul
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 08-18-2011, 01:28 PM   #5
67chevemall
67chevemall's Avatar
WD 40 and air compressor will clean it good! no valve needed if you are drum drum.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-18-2011, 03:51 PM   #6
Wrenchbender Ret
Paul
Exactly.
Wrenchbender Ret is offline   Reply With Quote
