Old 08-18-2011, 11:57 AM   #1
romes20
romes20's Avatar
Hard time starting when engines warm???
Hi everyone, here is my problem. When cold starting the truck turns on perfectly fine but when I turn it off and say run into a store and come back out. I try turning it on and the engine turns over but has a problem actually firing up. Sometimes I have to try this a few times before firing. I've been trying to do some research and came up with "heat soak" or installing a heat sheild or phenolic spacer on the carb? Sorry I'm fairly new with all this so if someone could help me out that'd be great. It also replaced the battery about a month ago so thats brand new.
Thanks in advance,
Jared
romes20 is offline   Reply With Quote
Old 08-18-2011, 12:41 PM   #2
Rons86
Rons86's Avatar
Re: Hard time starting when engines warm???
I know I'm on the wrong forum, but I had the same problem with my 86 using a 1406 Edlebrock carb and alum. intake. I solved my problem by putting a 3/4" spacer (wood laminate or composite) between the carb and intake. Took about 15 minutes and solved the problem immediately.
Rons86 is offline   Reply With Quote
Old 08-18-2011, 01:58 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
Edelbrock carbs have a tendency to have fuel boil problems when turned off hot and usually a phenolic spacer helps.
Edelbrock carbs seem to like fuel pressure constant below what a stock fuel pump puts out also.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-18-2011, 03:28 PM   #4
romes20
romes20's Avatar
awesome thanks guy, I have ordered the spacer.
Old 08-18-2011, 05:53 PM   #5
kevmic28
kevmic28's Avatar
I have an adapter plate between my ED carb and the stock manifold and still have the heat soak problem. Only does it when temps are over 90. It was way worse with the rochester on it though.
I have wondered if adding an electric fuel pump would help.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 08-18-2011, 06:01 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
How thick is the adapter? The phenolic spacer is not really an adapter, it is a spacer to prevent heat getting to the carb.
An electric fuel pump might help, but you will also need a pressure regulator,
Old 08-18-2011, 06:52 PM   #7
kevmic28
kevmic28's Avatar
Its actually pretty thick. About 1/2 to 3/4 of an inch thick. Made from aluminum.
1970 GMC truck
Old 08-18-2011, 10:56 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Yep, that us pretty thick and should have been good.
Sounds about like the one my son is going to use on his 454.
Old 08-18-2011, 11:56 PM   #9
kevmic28
kevmic28's Avatar
I have an Edelbrock performer intake that I have had for a while but have not gotten around to putting on. I may switch it over with a spacer once it cools off outside.
1970 GMC truck
Old 08-19-2011, 12:13 AM   #10
Andy4639
Old member
Andy4639's Avatar
Wink Re: Hard time starting when engines warm???
My 71 had the same problem until I installed the mini starter. My 71 is Fuel injected so it wasn't a fuel problem.
Link:
http://67-72chevytrucks.com/vboard/s...d.php?t=417721
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-24-2011, 12:49 PM   #11
romes20
romes20's Avatar
Once I get this spacer will my carb need to be re-adjusted???
Old 08-24-2011, 04:03 PM   #12
68 IRON
68 IRON's Avatar
I'm interested also....son's truck does the same thing. Edelbrock carb....didn't know those had a problem with heat. As far as adjustment...I wouldn't think so. Here we go....To The Top!
68 IRON is offline   Reply With Quote
Old 08-24-2011, 05:33 PM   #13
Eddie H.
Eddie H.'s Avatar
You can't use an aluminum spacer, because it conducts heat. You need a phenolic spacer in order to insulate the carb from the manifold heat.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-24-2011, 05:37 PM   #14
BIGKEV
What is your initial timing???
BIGKEV is offline   Reply With Quote
Old 08-25-2011, 11:33 AM   #15
romes20
romes20's Avatar
My spacer showed up today so I will install it and let you know if anything changes. Sorry how do I determine my initial timing? Im a newbie with engines.
Old 08-25-2011, 01:27 PM   #16
Rons86
Rons86's Avatar
Your carb will not need readjusting. Get a timing light to adjust engine timing. There are lots of threads on this procedure.
Old 08-25-2011, 02:37 PM   #17
c10seconds
c10seconds's Avatar
I had the same problem. It was because my starter was getting hot due to the headers being so close to it
c10seconds is offline   Reply With Quote
Old 08-25-2011, 11:00 PM   #18
MagmaJct
MagmaJct's Avatar
Gasoline has undergone changes over the years that old carburetted engines are just unable to adjust for. The major change is the oxygenation of the gasoline. Not only is that gas "leaner" to reduce CO emissions, but it also has a lower vapor point than gas of 30 - 40 years ago.
When the engine is running the carburetor gets a sufficient supply of cool fuel from the tank with minimal heating from the engine and related components. However, when the engine is shut off, and the cooling system is stopped. The heat is allowed to soak into the carburetor and the fuel system around and including the pump. This makes the gas vaporize and even "boil" out of the float bowl and into the intake manifold.
Not only does this flood the engine, but the vapor build up in the air cleaner causing a very rich mixture. In many cases the easiest way to get the engine started is to gradually press down the accelerator while cranking the engine. As it starts let off enough to maintain a stable RPM to purge the engine of the rich mixture.
This is the procedure I've used for years. Ideally, I'd like to find a phenolic spacer for my VW, but it seems I'll eventually have to make my own. I eventually found one for my truck, and it seems to work well. However, I will eventually install the Quadrajet.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 08-25-2011, 11:14 PM   #19
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
what carb ya got
John
1999 Toyota Tacoma 4x4
Old 08-26-2011, 12:17 PM   #20
romes20
romes20's Avatar
Originally Posted by oldblue1968chevy View Post
what carb ya got
Im running the Edelbrock Performance Series 750 with a manual choke.
What I did lastnight was took the carb off, cleaned it carb cleaner and decided to put it back on to see how it ran before putting on the spacer. Well it started a lot better (even when hot) but now it just doesnt sound right. I've been doing some reading on here and the internet and people have recommended playing with the mixture screws while checking out the accerlator pump.
What should I be checking next? Please keep this as simple as possible because Im a newbie trying to figure this out
Thanks.
Old 08-26-2011, 01:19 PM   #21
BIGKEV
Tell us everything you know about your engine combo!! Heads, cam, CI, intake, CR, fuel system, air cleaner, ignition setup! It sounds like there may be a few issues at play here.
Old 08-26-2011, 02:16 PM   #22
romes20
romes20's Avatar
From what I know its a 350, hooker headers, edelbrock intake, edelbrock air cleaner, MSD Ignition, not sure of the compression ratio or anything else as Im unable to look at the motor right now.
Old 08-26-2011, 08:25 PM   #23
stsalvage
Scrapper 1
stsalvage's Avatar
well the spacer is a good one timing is another.Is your motor grounded do you have all your grounds hook up are you running a one wire alternator or the old factory one.your power cables and ground cabled should be check and if you see them turning green best off to replace them with Big thick ones the more copper threads the better.make sure all your bolts are tight and change the fuel filter check your cap and rotor
stsalvage is offline   Reply With Quote
Old 08-26-2011, 08:49 PM   #24
oldblue1968chevy
what fuel pump, maybe too much pressure and running rich (mine is I know..)
John
