Old 08-18-2011, 12:17 PM   #1
mxjunkie80
mxjunkie80's Avatar
Quick bag question.
Installing bags on my 68. Is it ok to mount the bag directly to the flat plate that I bolted into my stock A-Arm and cross-member both top and or bottom?
mxjunkie80 is offline   Reply With Quote
Old 08-18-2011, 12:21 PM   #2
mxjunkie80
mxjunkie80's Avatar
Re: Quick bag question.
Do I have to use a cup I guess is what I'm asking?
Old 08-18-2011, 01:24 PM   #3
jimmydean
jimmydean's Avatar
You can use a cup or a plate, both work. I have seen mounting kits that are either a plate or a cup on the bottom.
I used a cup because it was easier to take apart if needed since the cup wasn't bolted to the arm. Some people worry it isn't safe, but it's no different than the spring that just sat in the bottom of the arm.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-18-2011, 02:03 PM   #4
mxjunkie80
mxjunkie80's Avatar
Thanks, exactly what I wanted to know.
Old 08-18-2011, 07:56 PM   #5
mxjunkie80
mxjunkie80's Avatar
Does anybody "slot" the lower holes where the bag mounts to in order to allow for forward and back A-Arm adjustment? Seems like a good idea or is it not important?
Old 08-18-2011, 09:31 PM   #6
SCOTI
SCOTI's Avatar
The C10 lower control arm shafts are located to a fixed position w/dowels on the x-member. They don't move fore/aft for adjustment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-19-2011, 01:35 AM   #7
mxjunkie80
mxjunkie80's Avatar
Mine are held on by those mini u-bolts and seems like I can mount it 3" either way? I'm I missing something?
Old 08-19-2011, 09:03 AM   #8
SCOTI
SCOTI's Avatar
Yes, the 'mini' u-bolts hold the shaft to the x-member.
Look @ the center of the u-bolt 'flanges' on the x-member & you'll see the 'pin' that slightly protrudes ( I believe they're on the front side). This dowel pin seats into a hole on the LCA shaft to positively locate it front to rear.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-19-2011, 10:01 AM   #9
DZL1
One day.....
DZL1's Avatar
If you want a lower stance, you can cut 1.5 inches off of the cup. It makes a BIG difference.
DZL1.
DZL1 is offline   Reply With Quote
Old 08-19-2011, 11:10 AM   #10
jimmydean
jimmydean's Avatar
DZL1.
It depends on the cup.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 08-19-2011, 12:04 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
DZL1.
You can cut 1.5" off,... if the cup is how tall to start with?
3"?
4"?
I've heard the cup can be no shorter than 1-5/8" total height.
Keith
Convert to disc brakes.
Old 08-19-2011, 06:47 PM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
...I've heard the cup can be no shorter than 1-5/8" total height.
This is for 73-87 arms. Early spring pockets are deeper, IIRC...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-20-2011, 01:09 AM   #13
mxjunkie80
mxjunkie80's Avatar
I don't have cups at all. Was trying to just use the plates. But won't go low enough. I never say the locating pins, hmm Thanks for the tips!
Old 09-07-2011, 06:31 PM   #14
crispo-71
hey question on that cup.. what size those it have to be.. i made one but its only 4 1/2 wide i need it wider right.. its on a 70 c10 short step
crispo-71 is offline   Reply With Quote
