Old 08-18-2011, 01:00 PM   #1
Trucknut57
Trucknut57's Avatar
Question Need help locating something like this!
HELP!!!
http://
See the connector on the ends of the cables, the bullet shaped things, with a threaded adjuster on the end!
Where can I find something like them ? A web site, local store, big chain store, anything!!
Plus, What is it called ??
Thanks.
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 08-18-2011, 01:29 PM   #2
Intimidator
Re: Need help locating something like this!
most hardware stores have something just like em, minus the tapered end.
(They'll be in the bin sections... sometimes near spacers or specialty hardware)
They have em in different lengths, but they're probably around a grade 5
Should run a couple bucks each.
Then just grab some nuts. (Whoa.... whoa....)
Tadda
Intimidator is offline   Reply With Quote
Old 08-18-2011, 01:37 PM   #3
redux2redux
redux2redux's Avatar
If that is a parking brake cable, you might want to try www.inlinetube.com
Here is a link to their parking brake stuff:
http://www.inlinetube.com/Brake%20Ca...ngs/cables.htm
redux2redux is offline   Reply With Quote
Old 08-18-2011, 01:42 PM   #4
solidaxel
solidaxel's Avatar
I like cost and service I get from Control Cables Inc
controlcablesinc.com
Just make sure your measurments are correct, they know what ends to use for your app.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-18-2011, 01:44 PM   #5
Intimidator
Hmmm... may have been mistaken on the part you meant if it is not threaded on both ends / through
Old 08-18-2011, 03:18 PM   #6
Trucknut57
Trucknut57's Avatar
Yes this is for an emergency brake cable. The picture is from the Lokar website.
One end has a place for the cable to slide into and is secured by two set screws, the other end is completely threaded so i can adjust the tension for the e-brake.
I have looked in most of the hardware stores in my area and nobody carries anything close to it and if it looks like it will work then its VERY thin and I wouldn't use it for my e-brakes.
- dcozzi
Old 08-18-2011, 04:05 PM   #7
solidaxel
solidaxel's Avatar
IMe thinks that is a Lokar product, the same with the cables at the carb for adjustments.
So there art two allen screws to depend on in case of a emergency!
I think I will stich with Control Cables!
LS 3 4L70E
Old 08-18-2011, 04:28 PM   #8
Trucknut57
Trucknut57's Avatar
I actually talked to somebody at Lokar today. Unfortunetly they don't just sell that piece, you have to buy the whole cable assembly. Go figure!
Solidaxel - Have you looked at todays vehicles? The cable end that connects to the actuator is only aluminum, and anyone who uses the Lokar cables has the same set screws. So either way its only for emergency use only.
- dcozzi
Old 08-18-2011, 05:12 PM   #9
mknittle
mknittle's Avatar
Looks like a trip to a machine shop to me.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-18-2011, 05:55 PM   #10
pgf545
pgf545's Avatar
When I worked at the parts store we some some long threaded nuts. I can't remember what they were called or what they were used for. There were with the studs. I bet you could take on of those and rethread it to suit your needs.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 08-18-2011, 05:57 PM   #11
pgf545
pgf545's Avatar
I was thinking something like this.
http://www.dormanproducts.com/p-5445-671-010.aspx
Bernie
Old 08-20-2011, 02:59 PM   #12
coralhead
coralhead's Avatar
Try a marine type store or website in the sailboat standing rigging section. There are fittings for attaching threaded studs to cable. West Marine or Defender Industries has these items. something like this may help.
http://www.defender.com/category.jsp...7595&id=312099
coralhead is offline   Reply With Quote
Old 08-21-2011, 11:50 AM   #13
dwcsr
Hollister Road Co.
dwcsr's Avatar
I use
http://store.controlcables.com/servlet/StoreFront
or
http://www.pushpullcontrolcables.com/controlcables.asp
Tell them what you want and they will make it.
dwcsr is offline   Reply With Quote
Old 08-21-2011, 12:06 PM   #14
solidaxel
solidaxel's Avatar
Dave have you used Push Pull cables for Ebrake cables on a AD truck?
Push Pull is a new one for me, are like Morris Cables?
Anyway I am logging there site,
LS 3 4L70E
Old 08-21-2011, 02:28 PM   #15
mbgmike
Thats a pretty easy part to make even at home with simple tools.if you want the tapered end rig it up to spin on grinding wheel and finish it off in a drill press
mbgmike is offline   Reply With Quote
Old 08-21-2011, 02:47 PM   #16
Trucknut57
Trucknut57's Avatar
I took the cables, my measurements, and a picture of what I needed to a local wire rope shop. They actually had a metal stud that they crimped onto the cable and I'm up and running.
Thanks for all the tips and help guys.
- dcozzi
Old 08-21-2011, 03:44 PM   #17
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have used both companies are one point or another for custom cables or pieces I needed made. For my 58 I needed a cable to go from a Ford cable to the original cross bar. They had the C connector and made the short adjuster cable for me.
Old 08-21-2011, 10:39 PM   #18
magicoolbus
magicoolbus's Avatar
Maybe Aircraft Spruce could help. Just searched for tierods and found tons of sizes.
http://www.aircraftspruce.com/catalo...es/tierods.php
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
