08-18-2011, 03:18 PM | #1 |
cold level in the coolant reservoir?
i changed my rad to an aluminum version and took a good look at my total cooling system.
I dont understand why there is a cold level in the coolant reservoir? isnt the only function of the reservoir "overflow"? so excessive coolant can flow freely at too high pressure in the rad? or does the coolant also get sucked back in? here is a old pic of my coolant tank, clearly showing the cool level.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
08-18-2011, 06:23 PM | #2 |
Re: cold level in the coolant reservoir?
Theoretically, I have read that the radiator should "put and take" from the reservoir as needed. I fill the reservoir to the cold level but I notice that the level drops a bit after a while - I think that the loose fitting fill cap allows for some evaporation.
08-18-2011, 07:37 PM | #3 |
I was always under the impression that it did indeed pull from the tank and into the radiator, as well as expand out of the rad to the tank.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
08-19-2011, 01:45 AM | #4 |
hmmm...okay, I thought it only spilled into the tank at overpressure, but I'll watch it the next couple of days and see if the level changes...thanks guys...
08-19-2011, 02:00 AM | #5 |
~Rest In Peace~
some will naturally evap as coolant loses its ph level and its strength, water will dissipate which will lower the level
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-19-2011, 08:00 AM | #6 | |
The "cool level" line is what allows you to set the proper fluid level, so that you can do it at your convenience (when the engine is cold) rather than after everything is heated up under there (like when checking automatic transmission fluid - which is a pain). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-19-2011, 09:24 AM | #7 |
The tank keeps the pressurized part of the system full. It also keeps from dumping coolant on the road.
Before they had coolant tanks, if you filled your radiator up full and went driving, when it got hot it would push coolant out and onto the road. Then when the radiator cooled down completely if you opened the radiator cap, it would be like an inch or so below full. Anytime you get it up to operating temperature, coolant comes out of the radiator and goes into the tank, and any time it cools down completely it sucks coolant back into the radiator. tanks an easy way to tell if you have enough coolant without touching or opening anything. |
08-19-2011, 01:35 PM | #8 |
alrighty tighty guys! thanks very much, that clears things up!
10-21-2011, 04:42 AM | #9 | |
this thread rocks! http://67-72chevytrucks.com/vboard/s...php?p=4852731/A/C Compressor |
10-21-2011, 09:32 PM | #10 |
The hip new term is 'coolant recovery system'.
