08-18-2011, 05:20 PM | #1 |
Horsepower/Torque
Have a question for everyone to give me they idea of how much horsepower and torque my combination will make. Once it is built and broke in I am gonig to have it dynoed for the hell of it to see what it does then I will post the results and we can see who got closest.
350 bored .040 over Flat Top Pistons Comp Cam High Energy 268/268 Duration .454/.454 Lift Edelbrock E-Street 64CC Aluminum Heads Compression about 9.3-1 Edelbrock EPS Aluminum Intake 1.5 Roller Rockers 600 CFM Edelbrock Carb I am building it for low to mid range torque and was just wondering what everyone was thinking it is going to make? Lets calculate both flywheel horsepower and wheel horsepower |
08-18-2011, 05:55 PM | #2 |
Champagne Taste on Beer Budget
Re: Horsepower/Torque
I am just taking this off the top of my head but I am guessing around 345rwhp.
Of course I could be way wrong but each engine is different. Good luck.
Coming Soon: Project 1970 Country Truck |
08-18-2011, 05:58 PM | #3 |
300 at the rear wheels and that's being generous with 9:1 compresson
08-18-2011, 06:35 PM | #4 |
i'm guessing 230 rwhp.
08-18-2011, 06:38 PM | #5 |
I'll say 350 at the crank around 275 to the wheels
08-18-2011, 06:42 PM | #6 |
no more than 275 at the wheels I would say
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
08-18-2011, 08:46 PM | #7 |
~Rest In Peace~
330/350 there still alot of info missing but this is just guessing like everyone else
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-18-2011, 09:16 PM | #8 |
I really have NFC, other than to say, a heck of a lot more than mine does!! (original '72 350 w/ 250K+ mi. and still going...pretty strong I'd say)
But just for giggles, put me down for 318hp @ the crank, and 260 on the whp. |
08-29-2011, 02:32 PM | #9 |
08-29-2011, 05:45 PM | #10 |
CAN'T FIX NOTHIN
just to help you make up your mind how to build your motor ,,,,,,,,,,,,,,
HORSEPOWER = HOW FAST YOU HIT THE WALL ! TORQUE = HOW FAR YOU MOVE THE WALL WHEN YOU HIT IT !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
08-29-2011, 05:54 PM | #11 |
I'll bite. 352 CHP/ 295 WHP.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
08-29-2011, 06:13 PM | #12 |
~Rest In Peace~
i cant wait to dyno mine im hoping for 800 hp and 700 ft tq ,i be happy with 700 hp and 550 ft lb .
08-30-2011, 05:02 AM | #13 |
Laid Back
About 290 rwhp
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
08-30-2011, 11:26 AM | #14 |
The info needed to get an accurate guess is as follows:
Motor Size: Juice: Timing Curve (initial and total): Compression: Air Induction: Air Conditioned: Carburetor: Intake: Heads: Head Extras, (if you have flow specs, or a link to flow specs, that would be great, heads can make as much as a 50~75 hp difference): Camshaft (specs or cam card link please): Cam Retard/Advance: Headers: Exhaust: And if you want 1/8 or 1/4 mile times, this info is also needed: Transmission: Converter Stall Speed: Tranny Extras: Rear Gears: Posi, spool, or open diff: Tires/Slicks: Tire Height: Traction Adders: Weight: |
