Old 08-18-2011, 06:51 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
alternator and radiator question
on a truck with a 350 motor and 350 automatic trans with air conditioning, I should have what size radiator in there?
also for that kind of truck i should be running a heavy duty alternator? I notice with the air conditioning on the truck and radio and even worse when i have on the lights or wipers the truck idles and the alternator guage dips down to about 8 then its just under 13 while moving
im thinking that i should put in an alternator that is at least 100 amps
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-18-2011, 07:07 PM   #2
tucsonjwt
Re: alternator and radiator question
As long as your truck starts OK I would not change your alternator. I put in a 160 amp alternator and it did not change the reading on the alternator (about like yours). If you have mega blaster amps and boom box then you might need a higher output alternator. The stock alternators are like 64 amps and seem to do the job fine. I think the gauges are only approximate in their readings anyway. A/C will drop the output but should not affect the state of battery charge over a long time period. I have also read that higher amp alternators require larger gauge wiring.
tucsonjwt is offline   Reply With Quote
