Old 08-18-2011, 06:57 PM   #1
dukcaln
dukcaln's Avatar
header gasket replacement ??
So I find myself with a header gasket leak on passenger side...looks like a fairly easy job (see pic)... my questions are 1) is there a better gasket than most or are they all the same 2) do I need to completly remove the header or are the gaskets able to slide into place if I just loosen the bolts enough to pull the header back and slide the old gasket out and new gasket in the tighten down 3) never done a header gasket any tips or tricks?
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 08-18-2011, 07:21 PM   #2
webfoot
Re: header gasket replacement ??
I like the percy's aluminum gaskets. i always blow through the thin areas of the composite ones. You don't need to completely remove the header. If you loosen the collector flange bolts you should be able to swing it away from the motor a bit. The holes on the ends of the header gaskets are slotted so you can get the 2 end bolts started without the gasket in the middle, and slide it over after you have 2 end bolts threaded.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-18-2011, 08:44 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i got percy's gaskets on mine , expensive but worth it xx carbon gasket by percy
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-18-2011, 09:33 PM   #4
sleepertruck72
sleepertruck72's Avatar
I replaced mine not long ago. I used Hookers gaskets probly not the best but they were fairly priced. I had to scrape off the old gasket on the header flange and the engine block . Also get some collector gaskets in case you need to replace them. Just my 2 cents
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-18-2011, 09:47 PM   #5
jondancer
I heard some don't even use gaskets.
jondancer is offline   Reply With Quote
Old 08-18-2011, 09:48 PM   #6
bigsnookmaster
bigsnookmaster's Avatar
I use Mr Gasket Ultra Seal gaskets. They work great with no leaks, and you can re-use them several times. They're the gray ones with a steel mesh inside them. .02
bigsnookmaster is offline   Reply With Quote
Old 08-19-2011, 12:12 AM   #7
dukcaln
dukcaln's Avatar
ok thanks guys, so I just need to remove the header bolts, take out the old gasket, if I dont have to scrap off any of it from the header and then just install the new gasket?.. what is the average cost for the gaskets?
SOLD 1972 chevy c10
Old 08-19-2011, 06:29 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I recommend using the metal foil type manifold gaskets. I've never had a problem with using them with headers and they are ultra cheap. (comes in a gasket set if you have one)
If you really want to go all out, give them a smear of RTV on both sides before installing. (but not needed)
You won't be blowing these out anytime soon!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
