Old 08-18-2011, 08:00 PM   #1
tazman87
tazman87's Avatar
2000 Blazer ZR2
looking to see who has cranked their torsion bars and what lift it had. and what about flipping the rear axel under the leafs. doing both of these will the blazer be level?
tazman87 is offline   Reply With Quote
Old 08-19-2011, 08:01 PM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 2000 Blazer ZR2
Doing the SOA you'll get close to 6" of lift, so your Torsion bars won't be enough. And even if they would crank up that much, the ride would be horrid.
If you want a cheap lift for your truck look into lift keys and shackles. They'll get you 2-2.5" up front and depending on the shackle .5-4" out back. For the level lock get 2" shackles and keys.
If all you want is the crank the torsion bars, a couple turns will level it out, but it looks like thats been done already on your Blazer2.
I would also suggest a body lift, but on these trucks they are ugly and noticably.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 08-19-2011, 08:03 PM   #3
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 2000 Blazer ZR2
Oh, and after cranking make sure to get an alignment, just a small crank will through the alignment out.
Old 08-20-2011, 02:39 AM   #4
tazman87
tazman87's Avatar
Re: 2000 Blazer ZR2
no i havnt done anything to it. it does have a nice rise to it in the front..figured that was stock height.
what are the keys?
Old 08-20-2011, 08:23 AM   #5
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 2000 Blazer ZR2
The keys are the pieces at the end of the torsion bars that do the cranking. Theres a bolt you turn, it pushes on the key, which twistes the torsion bar and thats where the lift comes from. If you get new keys they are indexed so when you put them in they start with a little bit more lift and can go higher.
Old 08-20-2011, 08:24 AM   #6
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 2000 Blazer ZR2
Keep in mind though as you twist the bar the ride will get stiffer.
Old 08-20-2011, 04:22 PM   #7
tazman87
tazman87's Avatar
Re: 2000 Blazer ZR2
Ok. So that and shackles in the rear
