Old 08-19-2011, 09:37 AM   #1
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
JB weld or solvent resistant epoxy
Got a killer deal on an aluminum radiator but it received some very minor damage during shipping. It's on the motor side and I'm thinking about just repairing it as apposed to going through the hassle of sending it back and all that is involved. I will be compensated for the inconvenience. There are a couple of very small tears in 2 coolant channels that can be reshaped with easy and sealed up. I have used JB for years and years but have recently been using epoxy on my carbs for sealing well caps and base ports. It's hard to go by the labels on a lot of this stuff because they say things like this:
Great for:
metal
wood
aluminum
plastic
toe nails
hair extensions
flat tires
broccoli and cauliflower
and on and on
Was just wondering if one might bond better to aluminum than the other. Thanks!
prostreetC-10 is offline   Reply With Quote
Old 08-19-2011, 10:06 AM   #2
Shane
Shane's Avatar
Re: JB weld or solvent resistant epoxy
why not just take it to a radiator shop and have them weld it up. i'd trust a weld over epoxy any day.
Shane is offline   Reply With Quote
Old 08-19-2011, 10:15 AM   #3
eagleuh1
eagleuh1's Avatar
Get it aluminum brazed. DocsBlocks sells brazing rod just for radiators, air coolers ....I just bought a torch and rod kit to make up AC lines from them. Good luck with it however you go. I know JB weld works great. I used it to fix an aluminum block on a Troy built tiller in a high stress area( Carb mount) Its held for 7 years no problems. Its an aluminum block too. Jim
eagleuh1 is offline   Reply With Quote
Old 08-19-2011, 10:39 AM   #4
cdowns
cdowns's Avatar
a job worth doing is worth doing right
Old 08-19-2011, 10:42 AM   #5
68gmsee
Active Member
68gmsee's Avatar
JB Weld is great but I still wouldn't trust it on a radiator except in an emergency or temporary basis. There's a lot of heat, moisture and pressure built up in a radiator which can accelerate the probablility of failure.
I've used it on exhaust manifolds and engine blocks but in this case, I'd trust a braze or weld before epoxy. Not saying it wouldn't hold, just prefer not to take the chance of getting stranded in the middle of a busy highway in 100 degree weather.
68gmsee is offline   Reply With Quote
Old 08-19-2011, 10:53 AM   #6
eagleuh1
eagleuh1's Avatar
Ahh, thats what AAA is for.
Old 08-19-2011, 10:59 AM   #7
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
I'm going to try some on broccoli and cauliflower.I'll get back to you on how it works out.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 08-19-2011, 11:12 AM   #8
brad_man_72
the boat guy
brad_man_72's Avatar
solder?
brad_man_72 is offline   Reply With Quote
Old 08-19-2011, 01:06 PM   #9
prostreetC-10
My Carbon Footprint
Well maybe we need to switch gears here. I do have a full size torch with brazing tips. Am I missing and easy fix here? What would I need to do?
Side note: I did fix a nice hole in a trans pan caused by a rock I ran over with JB weld and it never failed.
Old 08-19-2011, 01:09 PM   #10
68gmsee
Active Member
68gmsee's Avatar
For sure. However, it would still be a long wait while sitting in heavy traffic in cities like Houston or Austin with the temp at 105°. Also, I believe they will only tow to a shop???
Old 08-19-2011, 01:14 PM   #11
prostreetC-10
My Carbon Footprint
Guess I should also clarify that this is in my Camaro test car for my Holley carbs that will see 10-15 min use at a time and ceratinly will not be on the road in an temps over about 85*. Will also not be more than 1/2 mile from my house. Not saying that is a good reason to half-a$$ though!
