Old 04-08-2003, 08:21 PM   #1
crazy longhorn
Fabricate till you "puke"
Its alive!
The old longhorn has been upgraded to a 6 spd richmond trans. Hays billet 400 sb flywheel,centerforce dual friction clutch, ARP fasteners, modified stock clutch linkage with rod ends& a little carvin on the firewall to get a straight push on the parts. The trans crossmember was modified(notched & tab added to keep the drive line angles in check). She has been run in on the stands, & speedo gears set up. Ratios on the trans are 3.28, 2.14,1.57, 1.24,1, .76. With the 4.10 gears she will be redline in low @ 37 mph......6th gear will put me @ 100 mph @ an easy 3750, just a tick above peak tork on that 383! The snow/rain has put a damper on the road test, but it looks like i need to pull an axle on that 12 bolt ( me think she be twisted!) Oops! when we play, Iguess we have to pay crazyL, ready jam some gears
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2003, 08:31 PM   #2
meathead95
computer illiterate
meathead95's Avatar
congrats sounds like an awesome upgrade
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-08-2003, 08:53 PM   #3
krue
Designated A-hole!
krue's Avatar
Sounds like way too much fun!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-08-2003, 09:05 PM   #4
crazy longhorn
We cant never have too much fun
Old 04-08-2003, 09:14 PM   #5
racedvl
racedvl's Avatar
racedvl is offline   Reply With Quote
Old 04-09-2003, 01:24 AM   #6
wHATANERD
wHATANERD's Avatar
Cool
Sounds Fun!!!!!!
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
