Old 08-19-2011, 09:16 PM   #1
true74enduro
how about a bigger gas tank in our squars
i dont really like having to flip around to fill up and im not able to go to far with the lil 12 gals i got. i saw the tanks in lmc that fit in the same stock location and there bigger they come in a 20 gallon. and you can put it on either sides or both. anyone done this? i also saw in brothers that they have a rear mount gas tank. or i was thinking i could hunt down like an 82 i believe because some of them had a single larger rear mount tank. but the later years did not. any in put guys and gals?
true74enduro is offline   Reply With Quote
Old 08-19-2011, 09:36 PM   #2
79k30dually
Re: how about a bigger gas tank in our squars
All the trucks i've owned have had the larger tanks, However I've done rear tank installs by changing rear cross members and installing additional fill necks. Good luck, Ron
79k30dually is offline   Reply With Quote
Old 08-19-2011, 09:46 PM   #3
Goldfinger
Goldfinger's Avatar
Well you could mount a burb tank where the spare tire mount is. then you have a 40 gallon tank at the rear. if you have it slightly higher than the saddle you can gravity feed the side saddle tank removing the need for a tank switch. also cit a hole in the bumper behind the licence plate and mount the filler neck there while using a caprice spring mount for the licence plate so it would be a hidden filler the could be filled at the same time as the other tank.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-19-2011, 09:56 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Short beds can only fit a 16 gallon tank (factory) on either side. Long beds can fit either the 16 or 20 gallon tanks on either side. Some of the step sides (what years I don't remember) came with a rear mounted tank (capacity unknown to me)
You could alway put in a blazer/ suburban 30 gallon tank behind the rear axle. Do a search for it. Plenty of people on here have done so and done write ups of their progress.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 08-19-2011, 11:10 PM   #5
true74enduro
thanks i didnt even think about a blazer or a burb tank. i sure i wouldve sometime. that replacement side mount 20 tank was cool but a 40 just in the rear would be nicer
Old 08-19-2011, 11:15 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Its a pretty good option as long as your truck is at stock height. If your going to lower ir any, take in to consideration the larger rear tank does hang down.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-19-2011, 11:56 PM   #7
my4by2
my4by2's Avatar
Thumbs up Re: how about a bigger gas tank in our squares
How about something like this???
It's roughly 40 gallons, fully baffled internally & sits very nicely between the frame rails under the bed!!! It's even set-up to hold a stock GM sending unit/pump assembly for my LY6 6.0L engine!
Keven fabricated it from scratch - it's fully sealed inside & will be getting a coating Hot Rod black shortly to match a lot of other stuff. BTW - they relocated my filler using a door assembly off of a Suburban.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 08-20-2011, 06:50 AM   #8
Goldfinger
Goldfinger's Avatar
sharp looking tank and they aren't hard to make. did you coat the inside for rust prevention or is it galvanized?
Old 08-20-2011, 07:08 AM   #9
my4by2
my4by2's Avatar
It was coated by a local radiator shop with a product that WFO uses regularly for the fuel tanks they build, so should hold up pretty well if history is any indicator!
Old 08-20-2011, 07:22 AM   #10
Goldfinger
Goldfinger's Avatar
it looks very sturdy. it will last.
Old 08-20-2011, 07:46 AM   #11
my4by2
my4by2's Avatar
I'm hoping that it will - just gonna cringe every time I have to fill it up..... Even at just $3.50 a gallon that's like $125-140.00 each time & it'll probably only get around 17-19MPG unless I baby the crap out of it... Oh well - that's why I will have a little ricer car to putt around in for the commuting!
Old 08-20-2011, 08:06 AM   #12
Goldfinger
Goldfinger's Avatar
yeah but the way i see it when my tank is full i can go over 450 miles without refilling. which isn't to bad when i go no more than ten miles a day.
Old 08-20-2011, 12:44 PM   #13
camshaftgsxr
camshaftgsxr's Avatar
that is freaking awesome!!!
camshaftgsxr is offline   Reply With Quote
Old 08-20-2011, 07:48 PM   #14
79k30dually
How much $ ?
Old 08-21-2011, 02:54 PM   #15
joe231
joe231's Avatar
The license plate filler would be lower than the top of the tank so you would have a hell of a time trying get gas in there.....
CHEVY ONLY
Old 08-21-2011, 08:53 PM   #16
WarBeard
WarBeard's Avatar
Way to show us all up my4by2!!!!!
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 08-21-2011, 08:56 PM   #17
my4by2
my4by2's Avatar
Was never my intention - just an option I wanted to share with others. We had looked at using a Blazer tank at first, but I just didn't care for the look or the limited fuel capacity.
Old 08-21-2011, 10:45 PM   #18
Goldfinger
Goldfinger's Avatar
The bigger tanks would be great for traction.
Old 08-22-2011, 08:31 AM   #19
sumran
sumran's Avatar
At least for the first few runs.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 08-22-2011, 01:38 PM   #20
true74enduro
wow lots of input guys thanks. your crew cabs way nice
Old 08-22-2011, 02:01 PM   #21
sethv
sethv's Avatar
This literally made my day.
1981 K10 Scottsdale
305 ci | TH350 | NP208 |
60k miles
sethv is offline   Reply With Quote
Old 06-27-2012, 11:56 PM   #22
slimneverdies
slimneverdies's Avatar
Hey guys, Is it possible for me to mount this gas tank in this location in the pic? I have the truck torn apart and can't remember exactly where the box attaches to the frame rails....
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
