08-19-2011, 11:26 PM | #1 |
How low can i go?
So i was looking on the forums and one guy is saying that all his trucks had 6inch drop coils in the back without a notch......is this true how low can i go without a notch
Posted via Mobile Device |
08-19-2011, 11:38 PM | #2 |
Re: How low can i go?
it will hit on the frame that low i would rec doing a small c notch
08-20-2011, 12:42 AM | #3 |
Some will hit, others won't.
You should be good up to 6" of drop for normal driving w/o any pay-load. Starting adding stuff in the bed area & get on a crappy road & it could possibly bottom out. There would be less chance of that happening w/the 5" rear drop.
08-20-2011, 12:51 AM | #4 |
and how low would i want to go in the front? with a 6 in the rear?
08-20-2011, 12:53 AM | #5 |
The industry 'standard' is a 2" difference from front to rear from the factory (rear end is higher to compensate for loading the trucks bed w/crap). So if you're looking for a 6" rear drop, you'll want a 4" front drop.
08-20-2011, 12:58 AM | #6 |
thanx
08-20-2011, 02:37 PM | #7 |
Best way to go is anything after 4 inch c-notch the frame, although you can remove the stock bumptop and go to a pancake bumpstop instad but i really suggest notching after 4 inches.
