08-20-2011, 07:51 AM | #1 |
oi pressure reading
today I checked my oil pressure, because the gauge shows 15 all the time.
when I start the engine it goes up to 15 and then stays there, cold or warm, 1200 or 3000 rpm...always 15....wich isnt right? isnt it? to I took the wire of the sender today and grounded it. turned the ignition on and the gauge showed 60 (max). So the gauge is working. the sender is in a super bad location for me to get my big hands in. I noticed that the sender is screwed into a splitter, that is screwed into the top of the engine. could my sender just be dirty? so can I unscrew it, clean it with brake cleaner and then check again? or cant these things get dirty? and what is that other thing that is screwed into the splitter? its impossible to make a photo f it, because it is so dark in there and all the way at the back of the engine. hope you guys can help.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
08-21-2011, 03:54 PM | #2 |
Re: oi pressure reading
One sender is for the gauge, the other is for the idiot light in the dash.
Before getting carried away, you might get an aftermarket gauge and connect it to insure there is a problem with the gauge or sender to begin with. A SBC idling at 15psi is not all that unusual. But the pressure should come up with rpm's.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
08-21-2011, 04:27 PM | #3 | |
is it in ohm? like the fuel-tank sender? that is 0-80ohm....is this just like that?
08-22-2011, 02:08 AM | #4 |
A shop I know offered to connect a mechanical gauge. yes! I'll report back here when I know more.
