Old 08-20-2011, 10:41 AM   #1
AusTx68
AusTx68's Avatar
Wiper Transmission Question
My Texas inspection ran out so it's time to put the wipers back on. Haven't looked at them since I tore it down 2 1/2 years ago. Looking thru my old parts I seem to be missing the retaining clip and maybe a spacer where the wiper transmission connects to the wiper motor. I see there is a tab on the end of the wiper transmission arm but I'm not sure why. I'm thinking there should be square spacer. How does it connect? I checked the LMC catalog and it doesn't go into details.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-20-2011, 10:57 AM   #2
AusTx68
AusTx68's Avatar
Re: Wiper Transmission Question
One other question regarding the wiper switch. I have what is supposed to be a GM universal switch. It has four prongs and came with no wiring instructions. After messing with it I determined the following:
L = Low
H = High
P = Washer
B = Appears to be ground
My problem is low requires the Low and High wires to be grounded but they are independent of each other on the switch. So for now I only get one choice, high or low(if I put them together on a single terminal). Can't figure out how to get high and Low working independently. I planned to get a replacement motor and saw there is one with 4 connectors. Would that work?
Old 08-21-2011, 12:01 PM   #3
AusTx68
AusTx68's Avatar
anyone?
Old 08-21-2011, 08:21 PM   #4
turp mcspray
turp mcspray's Avatar
As far as the trans clip, once you have it in hand, it is self explanetory.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
