Positive Camber from ball joint replacement?
So a month or so ago, had an alignment done, before I realized my ball joints were shot. Last weekend I replaced the ball joints with Moog parts, and after reassembly, i have some obvious positive camber on both wheels.
Is this normal? Did the alignment shop compensate for bad ball joints and now it's over done?
My vehicles: 2003 Saturn ION 1 1988 V10 Suburban 4x4 Dad's: 68 C10 Stepside (work truck condition, runs though) 59 Apache Fleetside (rusted pile of metal - hopefully soon to be father/son project when he cleans out his garage!) Can see all three of these here |
#2 | ||
Re: Positive Camber from ball joint replacement?
Wait, I just realized that this is the 4x4 forum...Duh. Something is funny here... assuming that you are refering to the 88 burb in your signature. That would be a straight axle truck, so there really isn't much that most alignment shops can do to it anyway. Other than "toe", there is nothing that is actually an "adjustment". Caster and camber are essentially "built-in", they can be adjusted, but it is generally to compensate for damage....not part of routine maintenence.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 08-20-2011 at 02:55 PM. |
K5Camper
![]() Join Date: Mar 2004
Longhair is on the money. First why would an alignment shop proceed with an alignment if worn parts are on the truck? Settings would change as soon as you rolled it off the rack. I don't understand why shops do that. That being said camber is not an adjustable setting on a solid axle truck. You can tweak caster with a wedge between the housing and the spring, but camber itself is dictated by positioning of the inner "C" of the axle upper and lower ball joints. Seeing as how it's hard to put a ball joint in wrong to effect camber, the housing itself might be tweaked. Now that you've got ball joints in it, I'd see if the shop would put it back on the rack and recheck it to know for sure.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
![]() Join Date: May 2007
When you replaced the upper ball joints, were the threaded sleeves still there? There is an off-set sleeve that they can replace it with that will allow for some camber adjustment.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#5 | ||
The sleeve is actually part of the torque (installation sequence), so you couldn't just rotate it to where you wanted....The sleeve is not much bigger than the taper of the ball joint, so it couldn't be off-set by much anyway...
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
I had a 72 4x4 chevy once that had one in one side. That's the only reason I know they exist. My alignment guy pointed it out to me. When I replaced the ball joints, I replaced it with the regular threaded sleeve.
God is good!
Yep, Turp is right. BUT, they are generally only used to compensate for damage elsewhere, likely to the housing. A truck shouldn't "need" them. They come in different degrees. Otherwise known as camber/caster bushings...
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Yes, both uppers from Moog has these sleeves, and that crossed my mind as being a potential culprit too.
Either way, I took it back to the shop, they fixed the toe alignment, and the camber doesn't seem as bad now (both sides were inches out on toe supposedly, dont see how that's possible unless they did a horrible job last time). It still seems noticeable to me, but according to the shop they are within spec, or not far enough out to cause a problem. But as you've all said, it cant e adjusted readily anyway. I tried to place those sleeves approximately where the old ones were, as there aren't placement instructions with the package.
#9 | |
God is good!
