Old 08-20-2011, 12:34 PM   #1
tucsonjwt
Seat Belt Question - No Inertia Feature?
On my 83 C20, the seat belts do not tighten up when I yank on them. On all other vehicles with shoulder belts I have owned, yanking on the belt causes the belt to tighten. Is this normal? Since both belts act the same way I wonder if this is the way they are supposed to (non)function. This does not seem to afford much protection in the event of a crash.
tucsonjwt is offline   Reply With Quote
Old 08-20-2011, 12:36 PM   #2
78 Chevyrado
Re: Seat Belt Question - No Inertia Feature?
Maybe they're hanging up. mine in my 78 do it, and a lot of times they do it at bad times and can be really irritating. at some point I had to take the cover off my retractors and clean it all out and relube everything. then I was golden.
78 Chevyrado is offline   Reply With Quote
Old 08-20-2011, 12:41 PM   #3
camshaftgsxr
camshaftgsxr's Avatar
they only work on inertia, its time for new belts before you wrap your teeth around the steering wheel and your passenger head butts the dash
camshaftgsxr is offline   Reply With Quote
Old 08-20-2011, 12:58 PM   #4
tucsonjwt
The belts are not hanging up - they pull out smoothly all the way to the end of the belt. I don't know how seat belts go bad - does the lock mechanism break and is it repairable? It seems that this should be a simple fix, and since the belts themselves are in good shape I would like to try to save them.
Old 08-20-2011, 02:42 PM   #5
78 Chevyrado
inside the retractor there's a pendulum and a mechanism to lock it when you snatch the belt hard. In mine, the grease on those parts had hardened and wouldn't let those mechanisms move. when i cleaned it and re-greased em they moved freely and worked again.
These mechanisms don't have anything to do with the belt pulling out smoothly or not.
Old 08-20-2011, 03:04 PM   #6
tucsonjwt
Thanks rado. I will get out the socket set again and give it a look see.
Old 08-20-2011, 03:35 PM   #7
tucsonjwt
Did you have to drill out the rivets and remove the plastic cover to work on it? Also, I see two round white plastic covers inside (one for upper and one for lower tension?) - those appear to have steel springs inside - did you have to remove those covers also?
