Old 08-20-2011, 01:04 PM   #1
Joe Blaze
I made a _____ for my 67-72 Blazer! (post your homemade stuff here)
After seeing a thread like this on most of the other automotive sites i am on, i figured we could see what the brothers around here have made/modified/fabricated for use on their '67 - '72 Blazers.
Here is the rear tire- jerry can carrier the PO made for my '71:
Joe Blaze is offline   Reply With Quote
Old 08-20-2011, 10:06 PM   #2
Joe Blaze
Re: I made a _____ for my 67-72 Blazer! (post your homemade stuff here)
Come on, where are all the creative problem-solving brothers on this board? I was thinking something like this:
http://www.jeepforum.com/forum/f8/sh...stuff-1223169/
http://www.jeepforum.com/forum/f12/i...f-here-457361/
Old 08-21-2011, 05:50 PM   #3
BLUE THUNDER
BLUE THUNDER's Avatar
I made this to bolt in the factory spare tire carrier. It started out life as a Isuzu rodeo external tire carrier. Then the wheels in my head started turning. I knew that the wheel wld bolt on because the bolt pattern was the same as chevy.This is what I came up with.
BLUE THUNDER is offline   Reply With Quote
Old 08-21-2011, 05:53 PM   #4
BLUE THUNDER
And a couple more w/the finished product.
Old 08-21-2011, 06:14 PM   #5
Joe Blaze
Nice job, i love seeing guys using stuff made for other cars and adapting them for use to address their particular need. My current project is I am looking for some side steps or running boards that i can adapt for use on my '71. I saw some from a mid-'80s Jeep Wrangler in the junk yard the past week, but they didn't go far back enough to reach the frame rail.
Old 08-31-2011, 12:40 AM   #6
Joe Blaze
Man, where are all the creative, fabricating brothers on this board?
Old 08-31-2011, 10:01 AM   #7
Burt4x4
Burt4x4's Avatar
Duno what the PO was telling you but that is not "home made" that was made by Kayline the old Soft Top company out of Colorado...I know because I had one on mine back in the 90s. I bought their SoftTop and carrier.
Here is the only pic I have online and you can't even see it that well. That spare is a new 35" tire that would not fit inbetween the can baskets so I cut them off. I just upgraded to a 37gal tank so I didn't need to carry gas anymore.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-31-2011, 10:05 AM   #8
Burt4x4
Burt4x4's Avatar
What part of my rig would you like to see...I got fabed stuff everywere...
Old 08-31-2011, 05:11 PM   #9
swyfor5
swyfor5's Avatar
Right on Burt! Built not bought right! Still getting ready to fab up a spare carrier like yours for mine!
swyfor5 is offline   Reply With Quote
Old 09-08-2011, 04:07 PM   #10
RLONG
RLONG's Avatar
Nerf bars
RLONG is offline   Reply With Quote
Old 09-08-2011, 04:18 PM   #11
Joe Blaze
RLONG- Man, that is just what i wanted to do to my Blazer. Could you show us how you mounted them to your frame? I want to get past the rocker boxes, but the frame rails are a long way in. That is my current dilemma.
Old 09-09-2011, 01:14 PM   #12
RLONG
RLONG's Avatar
JOE Blaze i will try to get some picks this weekend
Old 09-20-2011, 02:56 PM   #13
Joe Blaze
Kickpanel speakers, emergency brake relocated
I wanted to put kickpanel speakers in my ’71 Blazer, and of course I ran into the usual problem of the emergency brake not leaving enough clearance for the speakers. I read on this forum about guys who cut the pedal off the arm and relocated it a few inches to the right. I was too lazy to remove the whole e-brake assembly, so I cut the pedal arm midway up with my angle grinder, and then cut off the foot pedal part. I then welded it back to the arm as far to the right as I could without altering the function. Finally, I welded the arm back to where I cut it off the assembly. Now I have ample clearance for the speaker and the speaker cover. There was no change to the function of the pedal. The steel used there is surprisingly soft and cut extremely easy with the cut-off wheel.
Before the modification:
Where I cut the arm off:
Pedal welded into the new position on the arm:
And finally all back together:
Old 09-20-2011, 03:14 PM   #14
Joe Blaze
Hey bruh- were you ever able to get those photos?
Old 09-21-2011, 12:11 PM   #15
Joe Blaze
You can see by the photos of the repositioned pedal, that it is more like the way pedals are positioned on modern cars, recognizing the possibility of adding speakers in that location.
Old 11-17-2011, 07:08 PM   #16
MrGoodpliers
MrGoodpliers's Avatar
I built a boat rack for canoes and kayaks that sits on the rails and uses the mounting holes for the top. Something I'm planning on doing next year is to take some parachute material or other lightweight nylon material to a seamstress and have her sew some magnets in the corners. When I park in a hot parking lot with the top off, I'll throw a couple of magnets on the dash and a couple on the rails or floor behind the seats to keep the seats and steering wheel from roasting in the sun.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 11-18-2011, 05:38 AM   #17
Joe Blaze
Do you have any photos of the project?
Old 11-19-2011, 02:51 PM   #18
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Transmission Cradle:
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 11-19-2011, 05:49 PM   #19
Ole Beater
F*** a duck!
Ole Beater is offline   Reply With Quote
