Old 08-20-2011, 01:06 PM   #1
mrmojo32
mrmojo32's Avatar
Rear end removal
I have rear axle issues on my 69 Burb so I got it pulled out but all I have left is to remove the parking brake cable from the brakes. What is the right way to remove them from the axle side? I can't seem to get the cable off.
Thanks!
1972 LWB
1969 4x4 Suburban
1989 4x4 Jimmy
mrmojo32 is offline   Reply With Quote
Old 08-21-2011, 12:08 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: Rear end removal
I assume you have drum brakes. You have to pull the drums and take the brakes apart to get to the parking brake bracket and cable out from inside the drum. Once you get that done, you will be able to pull the cable out from the bracket and through the back plate of the drums. Hope that helps.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
