Old 08-20-2011, 07:33 PM   #1
bigd65
bigd65's Avatar
Dash gauge readings
Ok so I got all my wiring problems fixed and the gauges working, however they are not reading correctly. The oil gauge is reading a little high, not bad but I know the oil pressure on these trucks don't go real high, that's just a Chevy. The temperature gauge goes way over to hot. I changed the thermostat and flushed the engine and new coolant and all. However the temp still goes way to hot and then slowly drops a little. The engine is by no means hot in fact you can actually put your hand on the valve cover. I'm thinking it's just the wrong senders or something. I got the ones for the diesel that it was originally but then again I did change the cluster and its now a gas 350, however they showed the same part numbers for the diesel and the gas engine for the same year
How can I tell what senders I need to buy, is there an ohm reading I can take from the gauge or something.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 08-20-2011, 10:50 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Dash gauge readings
Is the cluster properly grounded? Did you use any type of sealant on the sensors? The sensors should not use any sealant.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-21-2011, 10:12 AM   #3
bigd65
bigd65's Avatar
I'm gonna have to check that out today, I did but I think I cleaned them off, does go for the oil sender as well?
2017 Chevy Tahoe
Old 08-21-2011, 11:43 AM   #4
gchemist
gchemist's Avatar
Yes. Also check the engine to frame ground.
