Old 08-20-2011, 10:00 PM   #1
Jackie Mac
First time to Drop a Trans
Could someone tell me how many bell housing bolts hold the trans in? Its my first time removing a Transmission. Just bought a trans jack today and am doing as much research as possible before I start I have a 1986 With a 305 V8 and a 350 Lock out trans. Any tips from you guys is much apprec. Thanks
Jackie Mac is offline   Reply With Quote
Old 08-20-2011, 10:05 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: First time to Drop a Trans
its either six or eight..9/16 head IIRC make sure you disconnect the torque convertor from the flex plate too while youre doing that end of the removal ..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-20-2011, 10:39 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can find generic directions at Autozone: http://www.autozone.com/autozone/rep...00c1528004c68f
There are six bolts. If you use two long extensions and swival joint, you can reach all them.
Remember to unbolt the torque converter before you unbolt the transmission. Take your time. I removed the one in my truck myself. I had a little help to put it back in. I like using ramps on the front wheels with jack stands as backup supports.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-20-2011, 11:30 PM   #4
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
I knew it was an odd number, but I couldn't remember if it was 5 or 7, so I googled a pic.. It's 7 bell housing bolts and 3 torque converter bolts. Someone told me you can pull the tranny without unbolting the converter, but on every motor or tranny I've ever pulled, I've unbolted the converter prior to splitting the tranny from the engine.
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 08-20-2011, 11:49 PM   #5
VegasBruce
VegasBruce's Avatar
3 in the torque converter, and 6 in the bell housing. The T350 doesn't use the top, center bolt.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 08-21-2011, 12:29 AM   #6
lilpoindexter
lilpoindexter's Avatar
I've never seen that center top bolt on a Chevy I've taken apart.
lilpoindexter is offline   Reply With Quote
Old 08-21-2011, 12:40 AM   #7
VegasBruce
VegasBruce's Avatar
Its a leftover from the 50's, none trans in our squares use it.
Bruce
Old 08-21-2011, 05:52 PM   #8
Jackie Mac
Thanks to everyone for the info. I just broke a manifold stud off when removing the y-exhaust. I will drill it out and tap it later (DANG !) I really appreciate any other info ya'll have. Thanks again
Old 08-21-2011, 06:45 PM   #9
Hevy
Hevy's Avatar
Anyone ever use a motorcycle jack to remove a tranny? I was going to by a tranny jack but then looked at my cycle jack and thought hmmm...
Hevy is offline   Reply With Quote
Old 08-21-2011, 07:46 PM   #10
gchemist
gchemist's Avatar
I use a floor jack and a large piece of wood. Large enough for the oil pan to sit on.
Old 08-21-2011, 08:49 PM   #11
Toxic Redline
Toxic Redline's Avatar
I've done about 8 trans dropps and my favorite thing to use is two floor jack one for the transmission and one for the transfercase, i bought the $40 transmission jack adapter from northern tools that i use on the transmisson and i wouldnt do it another way, the adapter is TALL but on a lifted truck it works, if your not dealing with a transfercase it shouldnt be that hard to balance
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 08-22-2011, 08:23 AM   #12
sumran
sumran's Avatar
I removed several transmissions with a flat board I rigged to fit on my floor jack. Thought I was pretty smart until the tranny I was going to keep rolled off during removal and broke the corner off the case. I got it welded and it will probably be ok, but I will be buying the adaptor mentioned by Toxic Redline before I do another drop or install. I will probably install the motor and tranny as a unit when I put it back together.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 08-22-2011, 04:49 PM   #13
slammedLT1
slammedLT1's Avatar
Unbolting the torque converter makes for alot less cleanup when you slip it out of there! You dont wanna damage the bushing/seal in the front of the trans. Drop the pan and drain the fluid for sure before you puller out. That ll lighten it up some too then if she falls or the dipstick tube pops out you wont have a lake underneath the truck. If you're using a long extension and a swivel a 14mm socket fits alot tighter on the bellhousing bolts , makes it a lil easier so the socket doesnt fall off the head of the bolt when usin long extensions!. I use like 3 or 4 feet of extensions myself
DIGGER
1984 GMC Sierra 1500 LQ4 T56 12B Chopped 2 1/4, Dropped 6/7, Shaved, Yenko Stripes
2004.5 CCSB GMC 2500HD DMAX LLY, 6" Liftmaster, 6 Fox Resi 2.0 325/50/22" Kumho A/T on KMW's LBZ MP, 5"Ex, Bullydog GT
1996 ECSB GMC Sierra 1500 350/4L60E, FL Headers, 2450 Stall, 6" Pro Comp,3" BL, Shock Hoops, , TrXus STS 38's
slammedLT1 is offline   Reply With Quote
Old 08-23-2011, 01:21 AM   #14
Jackie Mac
Thanks again for all the great info!
Old 08-23-2011, 10:28 AM   #15
blazer2007
can the starter stay in?
blazer2007 is offline   Reply With Quote
Old 08-23-2011, 10:37 AM   #16
Your41Plague12
Your41Plague12's Avatar
I would honestly recommend just taking the starter out, it can't hurt. I've always done it, it's two extra bolts and a few wires to disconnect.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 08-23-2011, 11:18 AM   #17
slammedLT1
slammedLT1's Avatar
Personal preference. I don't remove the starter. It won't be in your way. Had to do this daily at a tranny shop so its just my opinion.
DIGGER
Old 08-23-2011, 01:47 PM   #18
bigblock73
yeller
bigblock73's Avatar
Support the back of the engine when the trans is out
bigblock73 is offline   Reply With Quote
