Old 08-20-2011, 11:31 PM   #1
gmebey
Ignition Wires
I need some advice....to be honest I'm in over my head on this project.
Anyway I need to replace the plug wires on my 69 C20. The prior owner changed out the distributor for a HEI unit and needless to say the stock plug wires are not right, and frankly a bit sloppy. I would like to clean it up, custom lengths and plug wire holders if needed.
So I need advice.
1) Is there any sets available?
2) What about the plug wire holders? Plastic or metal?
3) 90, 135 or straight angle?
Thanks in advance for the help
gmebey is offline   Reply With Quote
Old 08-20-2011, 11:35 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Ignition Wires
If your not lookin for anything special almost any wire manufacturer makes small block wire kits that require custom fab for custom installs. Most have several boot choices included in the box and plastic seperators. Accel to name one.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
