08-21-2011, 12:33 AM | #1 |
65 Ignition Wiring
Someone cut the plug off the ignition wiring when they moved the ignition to a late model column. I have replaced the column and I am moving the ignition back to the dash. I am going to connect the wires directly to the tabs with wire connectors.
I have a wiring diagram and understand there are 5 wires to connect. I think I have it figured out, but would appreciate some confirmation. Pink - Battery Red - Ignition BrownWhite - ACC Purple - Ground Dark Grey - SOL I appreciate your input. Thanks! |
08-21-2011, 01:07 AM | #2 |
Re: 65 Ignition Wiring
I figured it out after digging deep into the archives.
For the next guy.... Pink - Ignition Red - Battery BW - ACC Purple - SOL Dark Green - Ground |
08-21-2011, 01:36 AM | #3 |
But Found Her 25yrs Later!
Thanks for coming back and posting the solution.
I also had to figure out what went where. Here is the thread where I got my answer: http://67-72chevytrucks.com/vboard/s...d.php?t=427476
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
