Hello friends , Im looking for some advice on how to clean the sludge and rust out of a gas tank . I really dont want to purchase a new one . any info you can give me would be greatly appriciated .
fat old dude
![]() Join Date: Feb 2010
Re: Gas tank trouble
murtic acid and tank sealer
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
Yellow truck club
detergent and some lenghts of smaller chain sloshed around in the tank. also have friends that have put in the detergent and a lot of marbles and left it in the box of the truck as they drove it around for the week. Could also take it to the local rad shop for a cleaning. Just watch the gas fumes!
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
A gallon or two of orange juice and a few short lengths of chain sloshed around a few times a day for a couple days (alternating sides) will remove ALOT of the sludge and rust...not as aggressive as the muriatic acid.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
radiator shop will hot tank it - not sure of the cost but it will be clean - just my 2 cents worth
murtic acid will make more flash rust than you will know what to do with.and quick.
I did that once and ended up with more rust than I started with. |
these guys are really good. the make all kinds of automotive coatings.
http://www.kbs-coatings.com/tank-sealers.html
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
It's well worth what little money that a radiator shop charges to boil it out and flush it out.
You can get the loose crud out at the car wash by taking the sending unit out and spending a hand full of quarters to flush the tank out and then shine a light in it and see what you have going. |
